Re: Best dash speaker for b body
[Re: SomeCarGuy]
#3148145
06/02/23 10:21 AM
06/02/23 10:21 AM
Posts: 4,782 Holland MI Ottawa
2boltmain
Holland MI Ottawa
While both will work the Dual Voice Coil speaker is overkill in your application as its made to handle some power and produce hi fidelity (1970s term!) sound. Your system is neither powerful or hi fi- no insult intended. I would choose based on quality and being name brands are not what they used to be- some are not familiar- you'll have to read reviews and research those two speakers you have posted.
Keep old mopars alive.
[Re: 2boltmain]
#3148221
06/02/23 02:36 PM
06/02/23 02:36 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
[align:center][/align]I found some places showing the dual coil doesn’t work with oem 8-10 ohms. I called the place saying it does and they told me it does not.
I want my fair share
[Re: Pacnorthcuda]
#3148488
06/03/23 08:21 PM
06/03/23 08:21 PM
Posts: 117 SE-WI
skdmark
SE-WI
I installed the dual coil speaker last year in an E-body dash. Thankfully I had the dash out of the car. There was not enough clearance o the backside to drop the speaker in. I had to do some mods to the speaker chassis and mounting hardware to get it to fit without having to cut into the dash frame (others have). My original radio was gone so I replaced it with one from classic car stereo that looks OEM, but is modern internally. That took car of the ohm issue. https://www.classiccarstereos.com/1970-71-mopar-e-body-radio-chrome-buttons.html
[Re: srt]
#3148513
06/03/23 11:21 PM
06/03/23 11:21 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Most 60/70 Mopars used a a 4x10" oval speaker up front... EZ to make a drop-in replacement by taking (2) 3.5" speakers and mounting them on a an adapter plate made out of thin aluminum like a cookie sheet. By making template and cutting round holes for mounting the speakers and creating extended end ears for mounting to studs under the dash. Next is how to connect up depending upon what head unit U have.. 1. If using an mono AM Mopar OE head unit, the (2) speakers should be wired in series for an 8 Ohm load(3.2 Ohms + 3.2 Ohms). 2. If using an aftermarket stereo head unit the (2) speakers should be wired (1) to the left front output(3.2 Ohms) and (1) to the right front output(3.2 Ohms). Just my $0.02...
[Re: Sinitro]
#3148523
06/04/23 12:50 AM
06/04/23 12:50 AM
SomeCarGuy
Sounds like I should stick with a stocker. I had an am with a convertor setup in a 69 rr that did well enough for what I want. I know that one wasn’t upgraded internally. Just wanted to get the best I could for a fresh start on this car. I want this summer to be the last time crawling under the dash.
[Re: moparx]
#3148598
06/04/23 01:43 PM
06/04/23 01:43 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
there used to be a place called "crutchfeild" that was pretty good at sound systems, their techs knew their stuff, and were very friendly to work with. i don't know if that place is still around or not. Very much alive and well. https://www.crutchfield.com/ thank you sir ! i bookmarked that for future use. Absolutely a great place and a great staff still alive and well !!
[Re: srt]
#3148648
06/04/23 05:16 PM
06/04/23 05:16 PM
Posts: 916 Unfortunately back in New York
Nukechargerboy
There was a member here that made (and sold here) a dual speaker mount that is a replacement for the stock oval. Basically an aluminum plate and two 3" round element holes.Once speakers were fitted they could be wired for either mono or stereo (with a modified stock radio) for stereo. Just did this last summer. I couldn't tell you who I bought the bracket from. It was someone on here. I put JL speakers in with a retro radio. 5x7 in the back, sounds better than the fuel pump.
[Re: srt]
#3148797
06/05/23 09:55 AM
06/05/23 09:55 AM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
There was a member here that made (and sold here) a dual speaker mount that is a replacement for the stock oval. Basically an aluminum plate and two 3" round element holes.Once speakers were fitted they could be wired for either mono or stereo (with a modified stock radio) for stereo. I have one that he made for my 69 B-body if someone wants it.
[Re: NITROUSN]
#3149407
06/07/23 02:28 PM
06/07/23 02:28 PM
SomeCarGuy
I went with the sm electotech one. Mine ended up being a low ohm one that blew the transistor.
[Re: moparx]
#3149795
06/08/23 06:24 PM
06/08/23 06:24 PM
Posts: 5,445 So Cal
Sinitro
So Cal
what ohm speaker were the originals, and what happens to the radio if one just sticks in "any old speaker" that fits, of a different ohm impedance ? [i think that's the correct term to use] In the 50/60/70s most automotive OE speakers were 8 Ohm... In the 80/90s, as the OE head units increased in power by adding more channels and higher power (transistor-based) output stages, the speaker impedance spec dropped to 4 Ohms.. Today most replacement automotive speakers are 4 Ohms, some like the Infinity reference are 2.8 Ohms. My experience for most installs in our vintage Mopars, the biggest risk is putting a 4 Ohm speaker on an older OE head unit that was designed for 8 Ohms. Note that a 4 Ohm speaker requires 2X the current of an 8 Ohm speaker, and this additional current requirement frequently will burn out the amplifier output stage in an older Mopar vintage head unit. Final note, later aftermarket head units have higher current capability and also typically will have more built-in protection circuits for shorts and/or low ohm speaker loads. Just my $0.02...
