Wiring issue? #3147617
05/30/23 02:46 PM
05/30/23 02:46 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
1967 GTX, finishing up a restoration on it. Having an issue with the wiring. My windshield wiper motor is not working properly, it will turn on but not park or shut off correctly, I have to almost get the knob in half way between settings to shut off. It is a 915 variable motor that was restored. I am actually getting a shock sitting on the sill plate when I use the switch. All other wiring on the car works properly. I did have the battery negative grounded to the battery tray when I was putting the wiring in, but as mentioned everything seems fine, lights, fan blinkers etc. Battery negative now grounded to engine block and I noticed unless I run a jumper from the negative on the battery to the body of the car I get no power to the car anywhere. That doesn't seem right to me? I plugged a different 915 wiper motor in the bulk head and it works improperly like the one in the car, shock and all. Any help appreciated.
RS23L7 4-Speed
Re: Wiring issue? [Re: Mopar_Mike] #3147620
05/30/23 02:49 PM
05/30/23 02:49 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
!967 would have had a ground braid connected to the pass side cylinder head that bolted to the firewall , did you install that , and make sure that paint was not affecting it working ?
Re: Wiring issue? [Re: JohnRR] #3147623
05/30/23 02:59 PM
05/30/23 02:59 PM
Andrewh Offline
Andrewh  Offline
the wiper switch is grounded by the dash, so you also need to check the dash grounds as well.
new paint etc. might isolate the dash from ground and prevent it from working properly.
I don't remember the park circuit and how it works, but I do know trying to test that swtich outside of the dash gives a nasty shock.
Re: Wiring issue? [Re: Andrewh] #3147625
05/30/23 03:05 PM
05/30/23 03:05 PM
Danville, NH
Danville, NH
ok, that settles the shock from the switch as I have it just hanging down, I'll put it back in and check.
RS23L7 4-Speed
Re: Wiring issue? [Re: Mopar_Mike] #3147641
05/30/23 04:18 PM
05/30/23 04:18 PM
Danville, NH
Danville, NH
Mounted switch in dash, problem solved. Thanks all.
RS23L7 4-Speed
Re: Wiring issue? [Re: Mopar_Mike] #3147642
05/30/23 04:25 PM
05/30/23 04:25 PM
moparx Online content
moparx  Online Content
simple fixes for wiring snafus are the BEST fixes. up boogie laugh2
beer
