Wiring issue?
#3147617
05/30/23 02:46 PM
05/30/23 02:46 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
1967 GTX, finishing up a restoration on it. Having an issue with the wiring. My windshield wiper motor is not working properly, it will turn on but not park or shut off correctly, I have to almost get the knob in half way between settings to shut off. It is a 915 variable motor that was restored. I am actually getting a shock sitting on the sill plate when I use the switch. All other wiring on the car works properly. I did have the battery negative grounded to the battery tray when I was putting the wiring in, but as mentioned everything seems fine, lights, fan blinkers etc. Battery negative now grounded to engine block and I noticed unless I run a jumper from the negative on the battery to the body of the car I get no power to the car anywhere. That doesn't seem right to me? I plugged a different 915 wiper motor in the bulk head and it works improperly like the one in the car, shock and all. Any help appreciated.
RS23L7 4-Speed
Re: Wiring issue?
[Re: Mopar_Mike]
#3147620
05/30/23 02:49 PM
05/30/23 02:49 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
1967 GTX, finishing up a restoration on it. Having an issue with the wiring. My windshield wiper motor is not working properly, it will turn on but not park or shut off correctly, I have to almost get the knob in half way between settings to shut off. It is a 915 variable motor that was restored. I am actually getting a shock sitting on the sill plate when I use the switch. All other wiring on the car works properly. I did have the battery negative grounded to the battery tray when I was putting the wiring in, but as mentioned everything seems fine, lights, fan blinkers etc. Battery negative now grounded to engine block and I noticed unless I run a jumper from the negative on the battery to the body of the car I get no power to the car anywhere. That doesn't seem right to me? I plugged a different 915 wiper motor in the bulk head and it works improperly like the one in the car, shock and all. Any help appreciated. !967 would have had a ground braid connected to the pass side cylinder head that bolted to the firewall , did you install that , and make sure that paint was not affecting it working ?
Re: Wiring issue?
[Re: Andrewh]
#3147625
05/30/23 03:05 PM
05/30/23 03:05 PM
Mopar_Mike
Danville, NH
ok, that settles the shock from the switch as I have it just hanging down, I'll put it back in and check.
RS23L7 4-Speed
