Page 1 of 7 1 2 3 4 5 6 7
headers glowing red at idle #3147089
05/27/23 03:57 PM
05/27/23 03:57 PM
st.louis,mo.
dart games Offline OP
st.louis,mo.
i just brought a 400/512 engine big block.everything is new.timing at 34-36 locked,holley 1050 brand new carb from thumper.using 91 pump gas 10.5 compression.i went over this so many times..,check valve adjustment,took apart thumpers carbindy intake,total flow 270 heads.everything brand new.7 psi fuel pressure.engine wont idle no matter what i do to the carb.and headers glowing red.i brought this motor of hoping to go racing one more time in my life.i have that red 71 dart for sale in the for sale section.couldnt sell the car so i got a motor for it.now have 25k in this car.and all this
Re: headers glowing red at idle [Re: dart games] #3147096
05/27/23 04:15 PM
05/27/23 04:15 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Id guess you have a bad vacuum leak somewhere if the timing is right.
Are you sure the timing mark is correct?
Re: headers glowing red at idle [Re: GTX MATT] #3147097
05/27/23 04:25 PM
05/27/23 04:25 PM
ohio
dragon Offline
dragon  Offline
ohio
Check plug wires even if they are new ohm them had bad wires right out of box and make sure when installing the plugs you didn't bump one and close the gap up
Re: headers glowing red at idle [Re: dragon] #3147100
05/27/23 04:29 PM
05/27/23 04:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You timing is retarded.....Give it some more initial advance and that will go away
Re: headers glowing red at idle [Re: Al_Alguire] #3147109
05/27/23 06:02 PM
05/27/23 06:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
I’d be verifying everything about the timing was correct(and that the distributor is indeed locked)...... including the timing light.
Re: headers glowing red at idle [Re: fast68plymouth] #3147114
05/27/23 06:30 PM
05/27/23 06:30 PM
st.louis,mo.
st.louis,mo.
fast 68.i went over everything for days.its set and dist is locked.plug wires not crossed.its hitting on alll 8.wont idle have to keep reving it to keep it running
Re: headers glowing red at idle [Re: dart games] #3147115
05/27/23 06:32 PM
05/27/23 06:32 PM
st.louis,mo.
st.louis,mo.
al how do i get it initial advance if its locked.yes fast 68 used a timing light
Re: headers glowing red at idle [Re: dart games] #3147116
05/27/23 06:34 PM
05/27/23 06:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Have you tried doing a compression test on a couple cylinders?
Verified the timing mark on the damper is correct?
Re: headers glowing red at idle [Re: dart games] #3147117
05/27/23 06:41 PM
05/27/23 06:41 PM
Boise
Moparteacher Offline
Boise
Use a piston stop to confirm TDC mark on the dampner prior to using a timing light. Try another timing light. Just because everything is new doesn't mean it's good. You may want to smike the intake and confirm no vacuum leaks.
Re: headers glowing red at idle [Re: Moparteacher] #3147118
05/27/23 06:57 PM
05/27/23 06:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If it is ALL the tubes glowing it is TIMING period. You might wanna check and make ABSOLUTELY sure its not 180 degrees out as well. TDC on COMPRESSION stroke. Also that the distributor cap is truly on number one at TDC. If its ALL the headers its timing.
Re: headers glowing red at idle [Re: Al_Alguire] #3147119
05/27/23 07:04 PM
05/27/23 07:04 PM
st.louis,mo.
st.louis,mo.
al if it was a 180 out it would back fire though carb aqnd not run at all,yes all headers glowing red.have to keep giving it gas to stay running.and this is a brand new build
Re: headers glowing red at idle [Re: dart games] #3147120
05/27/23 07:08 PM
05/27/23 07:08 PM
st.louis,mo.
st.louis,mo.
fast 68.will do a compression test on it sunday
Re: headers glowing red at idle [Re: dart games] #3147127
05/27/23 07:48 PM
05/27/23 07:48 PM
AndyF Offline
AndyF  Offline
Most likely a timing problem but try a different carb just because that is easy to do. Could also be the cam timing if you didn't build the engine.
Re: headers glowing red at idle [Re: AndyF] #3147129
05/27/23 08:10 PM
05/27/23 08:10 PM
st.louis,mo.
st.louis,mo.
andy,i dont have another carb to try.you might be on to something with cam timing
Re: headers glowing red at idle [Re: dart games] #3147132
05/27/23 08:54 PM
05/27/23 08:54 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
I just updated one of my 440's to an electronic ignition. I had never previously had a timing light on it as it ran great from the moment I purchased the car. Put in the new distributor and couldnt get it to run right without putting an excessive amount of timing in it. After checking to make sure the balancer hadn't spun, I looked at the timing tab. I had a couple other big block covers around, so I laid one on the bench with the TDC mark at 6 oclock, put a piece of masking tape around the balancer and marked TDC on the balancer and the 0 degree mark on the tab. I did the same thing with the engine in the car I was working on. I removed both pieces of masking tape, laid them flat, and the distance between the marks was over 1 1/2" from one to the other. It equated to a 22 degree difference so I ended up having to put a dial back light on it. Total timing reads 57 degrees, but in actuality is 35 degrees when accounting for the 22 degree difference. At first glance the tabs looked to be in the same place, but clearly they weren't. It took me awhile to figure out what was going on, but as someone else previously mentioned the timing tab could be mis located and not be overly obvious at first glance.
Re: headers glowing red at idle [Re: IROC78] #3147136
05/27/23 09:22 PM
05/27/23 09:22 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Double check floats aren’t too high
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: headers glowing red at idle [Re: B3422W5] #3147138
05/27/23 09:56 PM
05/27/23 09:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Tdc is easy to check. I feel like it's timing but a vacume leak could be helping the problem. .
Re: headers glowing red at idle [Re: FastmOp] #3147155
05/28/23 05:18 AM
05/28/23 05:18 AM
st.louis,mo.
st.louis,mo.
has see through floats glasses.its ok,has stock timing cover and tab.has brand new,ati damper.i checked compression ok,and tdc.when you google the problem which i have many times trying to find something i over looked.it comes up more the timing is retarded.which andyf made a point on that.i brought a complete engine.i dont know when they installed the timing gear too much retard was put into it.everything checks out on the outside
Re: headers glowing red at idle [Re: dart games] #3147162
05/28/23 07:30 AM
05/28/23 07:30 AM
Sticky South
Rodenteliminator Offline
Sticky South
You might as well start from the bottom up, pull the front cover check the crank gear and timing chain alignment there might be an offset key installed the wrong way if they still make them or a multiple key way sprocket installed wrong, find TDC and reset your distributor and double check the lock out and rotor phase. Doug
Sorry honey I spent the rent
Re: headers glowing red at idle [Re: Rodenteliminator] #3147170
05/28/23 08:36 AM
05/28/23 08:36 AM
st.louis,mo.
st.louis,mo.
roden.i went over the lock out and rotor phase a few times at tdc.i understand i will have to pull the front cover.but can get off balancer in car as the rack and pinion is there.engine must come out.at this point im not sure if i will keep this any longer.this drag car will still be for sale.i cant keep on dumping mney in this im maxxed out.i thought i wasw getting a deal as the motor was local and brand new.this car is still for sale roller or as it is with this problem.the car is listed here under race cars.its a red 71 dart drag car car.if i pull the motor it will be in the fall.very much of a let down.THE MORAL OF THE STORY.NEVER TRUST ANYONES WORK
