Re: headers glowing red at idle
[Re: dart games]
#3147096
05/27/23 04:15 PM
05/27/23 04:15 PM
Posts: 5,166 CT
GTX MATT
CT
Id guess you have a bad vacuum leak somewhere if the timing is right.
Are you sure the timing mark is correct?
[Re: dragon]
#3147100
05/27/23 04:29 PM
05/27/23 04:29 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
You timing is retarded.....Give it some more initial advance and that will go away
[Re: Al_Alguire]
#3147109
05/27/23 06:02 PM
05/27/23 06:02 PM
fast68plymouth
So. Burlington, Vt.
You timing is retarded.....Give it some more initial advance and that will go away I’d be verifying everything about the timing was correct(and that the distributor is indeed locked)...... including the timing light.
[Re: dart games]
#3147116
05/27/23 06:34 PM
05/27/23 06:34 PM
fast68plymouth
So. Burlington, Vt.
Have you tried doing a compression test on a couple cylinders?
Verified the timing mark on the damper is correct?
[Re: Moparteacher]
#3147118
05/27/23 06:57 PM
05/27/23 06:57 PM
Al_Alguire
Las Vegas
If it is ALL the tubes glowing it is TIMING period. You might wanna check and make ABSOLUTELY sure its not 180 degrees out as well. TDC on COMPRESSION stroke. Also that the distributor cap is truly on number one at TDC. If its ALL the headers its timing.
[Re: AndyF]
#3147129
05/27/23 08:10 PM
05/27/23 08:10 PM
Posts: 680 st.louis,mo.
dart games
st.louis,mo.
andy,i dont have another carb to try.you might be on to something with cam timing
[Re: IROC78]
#3147136
05/27/23 09:22 PM
05/27/23 09:22 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Double check floats aren’t too high
[Re: dart games]
#3147162
05/28/23 07:30 AM
05/28/23 07:30 AM
Posts: 173 Sticky South
Rodenteliminator
Sticky South
You might as well start from the bottom up, pull the front cover check the crank gear and timing chain alignment there might be an offset key installed the wrong way if they still make them or a multiple key way sprocket installed wrong, find TDC and reset your distributor and double check the lock out and rotor phase. Doug
Sorry honey I spent the rent
