727 Trans Expert Needed
#3146219
05/22/23 05:13 PM
05/22/23 05:13 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I have a good working 727 trans out of a '78 Dodge truck with a 318 that I installed in a hopped up 1972 Challenger with a 340. All external band and linkage adjustments have been checked and kickdown lever is set to hit the back of the stop at WOT. Problem is the max shift point I can coax out of the trans is about 5000 RPMs while leaving shifter in drive. I'd like to raise the shift points closer to 6000 RPMs. Do I need to swap out and install a performance valve body, or governor weight, or is there something else I can do to raise shift points?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 727 Trans Expert Needed
[Re: BloFish]
#3146342
05/23/23 09:25 AM
05/23/23 09:25 AM
Posts: 4,687 Wichita
GY3
Wichita
The Trans-Go TF-2 kit will let you manually shift at whatever rpm you choose.
If you want it to shift at 6k rpm on its own (while in Drive) get the lighter weight governor kit from A&A.
[Re: GY3]
#3146428
05/23/23 04:28 PM
05/23/23 04:28 PM
RSI700VIPER
NW New Jersey
I think my problem is deeper than I originally thought. Took it out for the first time this year and with the pedal smashed to the floor, 1-2 upshift occurs at 2700 RPMs and 2-3 upshift occurs at 3200 RPMs. Checked kickdown lever and it's all the way back to the stop. Going to check line pressure next to see if pump is okay. Any other suggestions?
[Re: RSI700VIPER]
#3146610
05/24/23 01:20 PM
05/24/23 01:20 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With the throttle lever full back is the stop firm? On rare occasions the weld at the end of the throttle lever shaft will break loose from the cam and cause early shifts.
[Re: John_Kunkel]
#3146883
05/26/23 07:58 AM
05/26/23 07:58 AM
RSI700VIPER
NW New Jersey
Feels pretty firm to me but I'll double check. I ordered the T2 kit and will try installing it this weekend. Figured I'd replace the shifter shaft seal while I'm at it. Anything I should be looking for while I have the Valve Body out?
[Re: RSI700VIPER]
#3146889
05/26/23 08:56 AM
05/26/23 08:56 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Feels pretty firm to me but I'll double check. I ordered the T2 kit and will try installing it this weekend. Figured I'd replace the shifter shaft seal while I'm at it. Anything I should be looking for while I have the Valve Body out? Get the govenor weights , it's still going to shift lower than you'd like .
[Re: RSI700VIPER]
#3146894
05/26/23 09:25 AM
05/26/23 09:25 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Double check to make sure your low/reverse band servo shaft 30 cent o ring is not leaking on the backside of transmission while you have the valve body out
You just have to remove the transmission mount and six bolts for tail shaft housing and rotate the tail shaft slightly to clear the tab
Just did this on my 71 Superbee after the transmission shop did not replace that o ring five years ago - It was hard and brittle Fun laying on my back in the garage
Amazing how much of a mess that little o ring can leave on the garage floor after a winter hibernation
Trans shop did give me the o rings for free along with a newer servo shaft out of an overdrive transmission with double grooves or two o rings
Not a drop since but not a fun job to say the least on your back
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#3147047
05/27/23 11:56 AM
05/27/23 11:56 AM
RSI700VIPER
NW New Jersey
Where is this located? Pictures?
[Re: RSI700VIPER]
#3147048
05/27/23 11:58 AM
05/27/23 11:58 AM
RSI700VIPER
NW New Jersey
TF-2 will arrive today. I'll start with that and if shift points don't improve enough, I'll change the gov weights.
[Re: moparx]
#3147148
05/27/23 11:15 PM
05/27/23 11:15 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
please pick up the book : Torqueflight A-727, Transmission Handbook [How to rebuild or modify Chrysler's A-727 Torqueflight for all applications] by Carl H. Munroe. it's a great handbook, and does a step by step TF-2 installation with pictures, starting on page 165. it also details the rebuild process, as well as anything else you may want to learn about this transmission. well worth the price. https://www.amazon.com/Torqueflite-727-Transmission-Handbook-HP1399/dp/1557883998/ref=sr_1_2? might well be good advice as Trans go's Instructions used to be like walking a drunk duck. Loved the kits, but the instructions should have been written for a Dyson or Shark as they Sucked real well. Maybe they've redone them
[Re: TJP]
#3147376
05/29/23 09:26 AM
05/29/23 09:26 AM
Posts: 9,856 MI, usa
dvw
MI, usa
please pick up the book : Torqueflight A-727, Transmission Handbook [How to rebuild or modify Chrysler's A-727 Torqueflight for all applications] by Carl H. Munroe. it's a great handbook, and does a step by step TF-2 installation with pictures, starting on page 165. it also details the rebuild process, as well as anything else you may want to learn about this transmission. well worth the price. https://www.amazon.com/Torqueflite-727-Transmission-Handbook-HP1399/dp/1557883998/ref=sr_1_2? might well be good advice as Trans go's Instructions used to be like walking a drunk duck. Loved the kits, but the instructions should have been written for a Dyson or Shark as they Sucked real well. Maybe they've redone them I've found Trans Go's instructions very easy. Their tech line is great as well. Doug
[Re: dvw]
#3147458
05/29/23 04:21 PM
05/29/23 04:21 PM
TJP
Omaha Ne
please pick up the book : Torqueflight A-727, Transmission Handbook [How to rebuild or modify Chrysler's A-727 Torqueflight for all applications] by Carl H. Munroe. it's a great handbook, and does a step by step TF-2 installation with pictures, starting on page 165. it also details the rebuild process, as well as anything else you may want to learn about this transmission. well worth the price. https://www.amazon.com/Torqueflite-727-Transmission-Handbook-HP1399/dp/1557883998/ref=sr_1_2? might well be good advice as Trans go's Instructions used to be like walking a drunk duck. Loved the kits, but the instructions should have been written for a Dyson or Shark as they Sucked real well. Maybe they've redone them I've found Trans Go's instructions very easy. Their tech line is great as well. Doug It's been quite a few years since I did one, so possibly they have rewritten them. They use to jump all over the place. Start with the valve body, go to the case cup restrictor, back to the valve body, modify the plate, lets do the check balls, Oops, now let's drill one of the channels, back to scratching you backside, WHERE WERE WE ? Oh yeah set the line pressure, back to drilling. probably not quite that bad but close LOL
[Re: TJP]
#3148544
06/04/23 08:45 AM
06/04/23 08:45 AM
RSI700VIPER
NW New Jersey
Update! So I got my Trans-Go kit, dropped and split the valve body. Everything looks as expected in the kit instructions and the factory service manual. HOWEVER, while removing the Regulator Valve End Plate, the throttle pressure plug, valve and sleeve came flying out and shot across the work bench. According to Trans-Go and the FSM, there should not be a spring in this port but there clearly was one in there. My FSM is for a 1970 and the trans is a 1978 from a Ram Charger. Should I put the spring back in when reassembling?
[Re: RSI700VIPER]
#3148636
06/04/23 04:25 PM
06/04/23 04:25 PM
John_Kunkel
Rio Linda, CA
That redesigned pressure regulator configuration was new for '78, yes leave the spring in.
[Re: John_Kunkel]
#3148759
06/05/23 07:45 AM
06/05/23 07:45 AM
RSI700VIPER
NW New Jersey
Okay. Got the VB back together and it's ready to install. Last step is to change the accumulator spring and here is the problem. IT'S impossible! I've searched the internet and apparently I have to remove the tailshaft housing in order to pull the pin that holds the rear servo lever. I read one place where a guy had success prying the band and the lever apart and removing the square strut linkage thing to get at the servo but after trying his technique for an hour, I gave up. Can I just leave the trans kit spring out? I'm setting the trans up for street use only.
[Re: RSI700VIPER]
#3148851
06/05/23 12:55 PM
06/05/23 12:55 PM
John_Kunkel
Rio Linda, CA
No need to remove the lever pin, just back the adjuster all the way off and pop the link out. A little tricky getting it back in, be sure the link is properly centered when prying it back in. The heavy spring reduces the lag time on a manual 1-2 upshift but, yes, you could omit that step.
[Re: John_Kunkel]
#3148956
06/05/23 05:19 PM
06/05/23 05:19 PM
RSI700VIPER
NW New Jersey
John, I clamped the lever down as tight as it would go over the servo. I then reached under the lever and grabbed the edge of the band and pried it back tight against drum. This gave me maximum space to remove the strut. I could jiggle it around easily, but I pried under it and used every sort of pick, reach tool, screw driver, magnet, etc. I could find and it just won't come out. I see that the back side of the lever pin is 90% exposed and held in by a little tab of aluminum hanging off the tail housing. Can't I just cut that tab off, drive the lever pin out just enough to free the lever, perform the spring swap, then fashion a z-bracket and mount off the housing bolt to keep the pin in place?
[Re: RSI700VIPER]
#3148964
06/05/23 05:40 PM
06/05/23 05:40 PM
bee1971
Sobieski Wi
Trust me you don’t want to do this again
Earlier I mentioned the servo pin/shaft o-ring
You went this far , why not finish the job and do it correctly
Loosen and remove those six bolts for tail shaft
Support the transmission up front
Remove the transmission mount
Look at your linkage , and remove what’s necessary
All you have to do is rotate the tail shaft so the pin/shaft will clear the tab - I have never had to remove the tail shaft or had issues with the tail shaft gasket itself
You DO NOT have to remove the tail shaft
REPLACE O-RING
[Re: bee1971]
#3148981
06/05/23 06:57 PM
06/05/23 06:57 PM
RSI700VIPER
NW New Jersey
10-4. I'm surprise the gasket will survive. So I don't have to take out the rear shaft snap ring or drive shaft? There is no o-ring in the TF-2 kit. Do you know the size so I can pick one up at NAPA? Thx.
[Re: RSI700VIPER]
#3148992
06/05/23 07:48 PM
06/05/23 07:48 PM
bee1971
Sobieski Wi
No on the snap ring No on the drive shaft No on the speedometer cable housing
I had to go with my local transmission shop on the o-ring - I couldn’t find it anywhere locally thru jobbers They had a used double o-ring shaft for me also
Perfection - Not a drop in weeks Pan is 100% dry and just using a basic cork/rubber gasket with zero rtv or sealant
[Re: bee1971]
#3149091
06/06/23 10:43 AM
06/06/23 10:43 AM
RSI700VIPER
NW New Jersey
I ended up supporting the trans in the front, removed the trans mount, linkage, etc. and spun the housing about 5 degrees and got the shaft out as you suggested. Took all of 20 minutes. My shaft has the double 0-rings and they looked in good shape so I just reused them. The servo spring supplied in the TF-2 kit was so stiff that I had to jack off the floor to press the servo in far enough using a socket in order to get the snap ring on. I'm going to install the VB tonight and hopefully I didn't mess anything up and my shift points improve. I'll use the cork gasket suppled in the kit without rtv. I also installed new shaft seals.
[Re: RSI700VIPER]
#3151862
06/15/23 07:41 PM
06/15/23 07:41 PM
RSI700VIPER
NW New Jersey
Update - So I test drove the car today after installing the TF-2 kit and I'm somewhat disappointed. The WOT 2-3 shift is much improved and occurs about 4500 as apposed to about 3300 but the 1-2 shift is l occurring about 2800 rpms but better than the 2500-2600 rpms I was getting before. Also, the kickdown from 3 to 2 lags and takes about 2-3 seconds to downshift. The 2 to 1 downshift is non existent. I check linkage and throttle lever is all the way back against the stop at WOT. Trans shifts tight with no slippage. Bands adjusted per kit specs. What's next, governor weights? line pressure check? New Trans??
[Re: RSI700VIPER]
#3151882
06/15/23 08:36 PM
06/15/23 08:36 PM
dvw
MI, usa
Update - So I test drove the car today after installing the TF-2 kit and I'm somewhat disappointed. The WOT 2-3 shift is much improved and occurs about 4500 as apposed to about 3300 but the 1-2 shift is l occurring about 2800 rpms but better than the 2500-2600 rpms I was getting before. Also, the kickdown from 3 to 2 lags and takes about 2-3 seconds to downshift. The 2 to 1 downshift is non existent. I check linkage and throttle lever is all the way back against the stop at WOT. Trans shifts tight with no slippage. Bands adjusted per kit specs. What's next, governor weights? line pressure check? New Trans?? Did you take the governor apart? Did you check the governor seal rings? some governors have a screen to catch debris. Even a low performance governor should shift higher. Unless the throttle pressure linkage isn't correct. I'm asuming you checked the throttle pressure valve and cam along with the shift valves for freedom of movement when you installed the TF 2 kit? Doug
[Re: RSI700VIPER]
#3151996
06/16/23 10:39 AM
06/16/23 10:39 AM
JohnRR
U.S.S.A.
Update - So I test drove the car today after installing the TF-2 kit and I'm somewhat disappointed. The WOT 2-3 shift is much improved and occurs about 4500 as apposed to about 3300 but the 1-2 shift is l occurring about 2800 rpms but better than the 2500-2600 rpms I was getting before. Also, the kickdown from 3 to 2 lags and takes about 2-3 seconds to downshift. The 2 to 1 downshift is non existent. I check linkage and throttle lever is all the way back against the stop at WOT. Trans shifts tight with no slippage. Bands adjusted per kit specs. What's next, governor weights? line pressure check? New Trans?? 2 - 1 downshift should be non existent except for a full stop , downshifting into first moving is a good way to take out the rear sprag with no low band applying, so I believe the kit is working as designed. Did you check to make sure the throttle valve lever weld underneath was not broken ? What are you using for Throttle vale linkage , stock or aftermarket cable ? Put a gauge on it and do some checks , do you have a shop manual ?
[Re: dvw]
#3152618
06/19/23 08:33 AM
06/19/23 08:33 AM
RSI700VIPER
NW New Jersey
Update - So I test drove the car today after installing the TF-2 kit and I'm somewhat disappointed. The WOT 2-3 shift is much improved and occurs about 4500 as apposed to about 3300 but the 1-2 shift is l occurring about 2800 rpms but better than the 2500-2600 rpms I was getting before. Also, the kickdown from 3 to 2 lags and takes about 2-3 seconds to downshift. The 2 to 1 downshift is non existent. I check linkage and throttle lever is all the way back against the stop at WOT. Trans shifts tight with no slippage. Bands adjusted per kit specs. What's next, governor weights? line pressure check? New Trans?? Did you take the governor apart? Did you check the governor seal rings? some governors have a screen to catch debris. Even a low performance governor should shift higher. Unless the throttle pressure linkage isn't correct. I'm asuming you checked the throttle pressure valve and cam along with the shift valves for freedom of movement when you installed the TF 2 kit? Doug I haven't touched the governor yet. Linkage is adjusted correct with all factory components installed. Pressure valve was adjusted per TF-2 instructions and valved moves in and out freely.
[Re: JohnRR]
#3152619
06/19/23 08:38 AM
06/19/23 08:38 AM
RSI700VIPER
NW New Jersey
Update - So I test drove the car today after installing the TF-2 kit and I'm somewhat disappointed. The WOT 2-3 shift is much improved and occurs about 4500 as apposed to about 3300 but the 1-2 shift is l occurring about 2800 rpms but better than the 2500-2600 rpms I was getting before. Also, the kickdown from 3 to 2 lags and takes about 2-3 seconds to downshift. The 2 to 1 downshift is non existent. I check linkage and throttle lever is all the way back against the stop at WOT. Trans shifts tight with no slippage. Bands adjusted per kit specs. What's next, governor weights? line pressure check? New Trans?? 2 - 1 downshift should be non existent except for a full stop , downshifting into first moving is a good way to take out the rear sprag with no low band applying, so I believe the kit is working as designed. Did you check to make sure the throttle valve lever weld underneath was not broken ? What are you using for Throttle vale linkage , stock or aftermarket cable ? Put a gauge on it and do some checks , do you have a shop manual ? I did check the weld per your previous post. Linkage is bone stock and correct for this application. I'm not sure what would cause the 2-3 shift to vastly improve after installing kit bit the 1-2 shift is still early at WOT. Coming home from a show yesterday, I was going atbout 30 mph up a hill and punched the throttle. Took almost 3 seconds to kick down into second.
[Re: TJP]
#3153113
06/20/23 06:11 PM
06/20/23 06:11 PM
JohnRR
U.S.S.A.
Not wanting to hijack the thread, but am I understanding that with the TF2 Kit and the part throttle kickdown from 3-2, the ability to kickdown from 3-1 at low speed is eliminated? Can't answer that , it's been a long time since I installed one in anything and my play cars are 4 speeds. , but a 3-1 down shift ...
