Valley pan question #3145327
05/18/23 01:36 PM
05/18/23 01:36 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm in the process of installing my intake manifold (new Performer RPM on new Performer RPM heads on a 400 block) and have a question about the valley pan and gaskets. According to the instructions Edelbrock provided, I should use the 4 gaskets along with the valley pan. I tested the fit by first setting the manifold on the motor without the valley pan and checked for bolt hole alignment. They looked perfect. I also checked fit with a feeler gauge and I can get a .005 gauge to slide in there and when I go to a .006 it will not fit in the middle but slides in with some drag on the ends.With just the pan and the manifold sitting on it they still look good. I then put the valley pan and a gasket between it and the head and set the manifold back on. The holes in the head are now at the bottom of the holes in the manifold. I didn't try adding the gasket between the pan and manifold being the hole alignment was already off with just the gasket between the pan and heads. So, it looks like I will have to skip the gaskets but was just wondering if anyone else has had this problem when trying to use the gaskets.
Re: Valley pan question [Re: 6PAX] #3145356
05/18/23 03:27 PM
05/18/23 03:27 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Stock iron intakes fit without any gaskets BUT all aluminum intakes should use two thin "paper gaskets" per side - one on each side of the of the pan. Its easiest if you glue them on ahead of time. If necessary, enlarge the bolt holes on the intake but more important is the port alignment.
Re: Valley pan question [Re: Stanton] #3145367
05/18/23 04:25 PM
05/18/23 04:25 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
I have in the past cut my own paper gaskets from extra thin material because the ones provided were too thick, but that was with iron heads and an aluminum manifold.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Valley pan question [Re: 6PAX] #3145455
05/18/23 11:33 PM
05/18/23 11:33 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The gaskets that come with the tubs are too thick. Thinner ones are available.
.015 thick gaskets. intake-Facing-gaskets-Set-of-4
Re: Valley pan question [Re: GomangoCuda] #3145478
05/19/23 02:07 AM
05/19/23 02:07 AM
Some of the Fel Pro 440 Hi Po valley pans (I'll try and find it and post that part number tomorrow on here) came with two thin gaskets, I can't remember if they were.030 or .015 now confused
Re: Valley pan question [Re: Cab_Burge] #3145544
05/19/23 12:03 PM
05/19/23 12:03 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I measured the ones I have and they are the .030's.
Re: Valley pan question [Re: 6PAX] #3145588
05/19/23 02:27 PM
05/19/23 02:27 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The intention of the supplementary fiber gaskets were specifically for aluminum intake manifolds ... having potential out-of-flatness. They originated with the factory 1969 aluminum 440-6 intakes. They can be used with any manifold... cast iron or aluminum... but always best to use with any aluminum intake as they do tend to flex and can have some corrosion, as well as out-of-flatness in due time.
I'm a former applications engineer from a major gasket mfgr.
Re: Valley pan question [Re: Mopar Mitch] #3145735
05/20/23 09:56 AM
05/20/23 09:56 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Does anyone know if anyone else makes .015 gaskets other than 440 Source? I was hoping I could pick some up at a local auto parts store.
Re: Valley pan question [Re: 6PAX] #3145737
05/20/23 10:00 AM
05/20/23 10:00 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Have you looked into the Super performance gaskets. I believe they come in that size
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Valley pan question [Re: 6PAX] #3145784
05/20/23 01:33 PM
05/20/23 01:33 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Something that helped with my valley pan fitment was to use the manifold as a metal brake to get a better seal.
I bolted the valley pan up to one side of the manifold and then lightly struck the edge with a hammer. This made the bend sharper and more form fitting to both the heads and manifold. The pan fit better on the heads and did not fight the manifold when installing. It also helped eliminate some of the small intake leaks I was getting from the lifter galley.
Re: Valley pan question [Re: 6PAX] #3145837
05/20/23 04:24 PM
05/20/23 04:24 PM
Try contacting SCE gaskets, I think I had them make me some of the .015 440 style intake gaskets years ago, I have two pair left now shruggy
They use to make them in .015,.030, .060, .090 and .120 thick. The company has been bought and sold several times since them and moved their headquarters and manufacturing plant several times also confused
Re: Valley pan question [Re: 67mprfan] #3145892
05/20/23 08:00 PM
05/20/23 08:00 PM
GomangoCuda Offline
GomangoCuda  Offline
Superformance Products has the .015 gaskets. Page 8 in their catalog.
http://www.superformanceproducts.com/catalog.php
Re: Valley pan question [Re: GomangoCuda] #3146022
05/21/23 03:47 PM
05/21/23 03:47 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Another option
Hughes Engines
Intake Gaskets with Silicone Seal Bead
.016
.030
.060
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Valley pan question [Re: 6PAX] #3146135
05/22/23 10:13 AM
05/22/23 10:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I like to use at least one paper gasket per bank, even with iron heads, and I will have the intake cut so I don't have to butcher a perfectly good intake by filing the bolt holes.
When you were able to get a feeler blade in was this with a gasket or no gasket ... if a gasket which the paper or the valley pan and has the valley pan embossing already been crushed, It's a little confusing?
Re: Valley pan question [Re: JohnRR] #3146140
05/22/23 10:45 AM
05/22/23 10:45 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
It's a new valley pan, not crushed. I checked with the feeler gauge with just the intake, no pan or gaskets. If using only one gasket, which side of the valley pan?
Re: Valley pan question [Re: 6PAX] #3146155
05/22/23 11:50 AM
05/22/23 11:50 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
This makes absolutely NO sense !!! Once and intake is cut its no longer guaranteed to fit any other motor. On the other hand, elongating the bolt holes leaves the important dimensions intact.
Re: Valley pan question [Re: 6PAX] #3146170
05/22/23 01:00 PM
05/22/23 01:00 PM
I put them on the head side (if both gaskets won't fit properly) to help prevent oil being suck up into the intake manifold up wrench scope
I've reused the valley pans with gaskets on them many times with no problems boogie
Re: Valley pan question [Re: 6PAX] #3146182
05/22/23 01:54 PM
05/22/23 01:54 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I was never able to find premade gaskets in the thickness I wanted… so making your own out of bulk gasket material is an option, it’s not too bad of a job
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Valley pan question [Re: Cab_Burge] #3146267
05/22/23 08:44 PM
05/22/23 08:44 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
So, if I end up using one or both gaskets, is any sealant necessary on the gaskets? I'm not referring to adhesive to attach the gasket to the pan but rather around the ports as is often done when just using the pan.
Re: Valley pan question [Re: 6PAX] #3146310
05/23/23 02:03 AM
05/23/23 02:03 AM
I don't use sealant on the intake gaskets, they should seal without it work I do make sure the intake manifold head surface is square to the heads before using it, if it has say .009 on the top surface between the intake manifold and the head and .012 on the bottom on one corner and different measurements on the other 3 corners without the valley pan I have the intake manifold machine so I can have say .0010 on the bottom and.0030 max on the top so the gaskets will be pinched in tight on the bottom surfaces to help seal the gasket to the heads and help keep oil from being suck into the heads from the lifter valley work scope wrench twocents
