Who sells NGK BCP6ES? #3145024
05/16/23 07:18 PM
05/16/23 07:18 PM
South San Francisco, Ca
70sixpkrt Online content OP
70sixpkrt  Online Content OP
Who sells NGK 4930 (BCP6ES)? Summit says they have been discontinued.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Who sells NGK BCP6ES? [Re: 70sixpkrt] #3145046
05/16/23 10:07 PM
05/16/23 10:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Try Google whistling
Re: Who sells NGK BCP6ES? [Re: TJP] #3145061
05/16/23 11:22 PM
05/16/23 11:22 PM
I did and a lot of websites says discontinued.
4-speed
3:54 Dana
Re: Who sells NGK BCP6ES? [Re: 70sixpkrt] #3145063
05/17/23 12:01 AM
05/17/23 12:01 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yep, almost all or everyone that I searched (Amazon, ebay, motorcycle, ATV parts distributors, etc.,) say NOT AVAILABLE??
Re: Who sells NGK BCP6ES? [Re: A12] #3145092
05/17/23 08:50 AM
05/17/23 08:50 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just bought 8 yesterday from Advanced Auto.They were in stock.
Re: Who sells NGK BCP6ES? [Re: bonefish] #3145097
05/17/23 09:07 AM
05/17/23 09:07 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Napaonline.com shows them available
Ebay shows lots of listings
Re: Who sells NGK BCP6ES? [Re: Sniper] #3145103
05/17/23 09:40 AM
05/17/23 09:40 AM
Thanks. Going to Napa today to see if they have them.
4-speed
3:54 Dana
Re: Who sells NGK BCP6ES? [Re: 70sixpkrt] #3145119
05/17/23 11:53 AM
05/17/23 11:53 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Try BCPR6ES.
Same specs but has a resistor.
Re: Who sells NGK BCP6ES? [Re: fast68plymouth] #3145136
05/17/23 01:35 PM
05/17/23 01:35 PM
I got the last 16 from Napa.
4-speed
3:54 Dana
Re: Who sells NGK BCP6ES? [Re: fast68plymouth] #3145137
05/17/23 01:36 PM
05/17/23 01:36 PM
Originally Posted by fast68plymouth
Try BCPR6ES.
What is the difference between a resistor and non resistor?
4-speed
3:54 Dana
Re: Who sells NGK BCP6ES? [Re: 70sixpkrt] #3145141
05/17/23 01:53 PM
05/17/23 01:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
Re: Who sells NGK BCP6ES? [Re: fast68plymouth] #3145143
05/17/23 02:12 PM
05/17/23 02:12 PM
moparx Online content
moparx  Online Content
unless the application is an all out race effort, resistor plugs will work fine.
just choose the heat range that will work the best for a particular combination.
beer
Re: Who sells NGK BCP6ES? [Re: fast68plymouth] #3145148
05/17/23 02:28 PM
05/17/23 02:28 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
On my race bikes I try to avoid a resistor spark plug. Cars and motorcycles have been coming with a 5k ohm resistor spark plug caps for a long time and I see no reason to add in more spark energy resistance. Maybe if my AM radio starts to have RFI then and only then would I run an additional resistor in the form of a resistor spark plug. Just me.
Re: Who sells NGK BCP6ES? [Re: A12] #3145202
05/17/23 08:21 PM
05/17/23 08:21 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Facts are stubborn things.
Re: Who sells NGK BCP6ES? [Re: larrymopar360] #3145295
05/18/23 11:14 AM
05/18/23 11:14 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Superceded to a 2330 stock number. Same plug.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Who sells NGK BCP6ES? [Re: 6PKRTSE] #3145305
05/18/23 12:08 PM
05/18/23 12:08 PM
No. 2330 is the Resistor plug.
4-speed
3:54 Dana
Re: Who sells NGK BCP6ES? [Re: A12] #3145346
05/18/23 02:21 PM
05/18/23 02:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
WHAT IS A RESISTOR SPARK PLUG?
Spark Plug Resistor Location
At the moment the spark jumps the gap it causes a high frequency burst of energy, known as RFI (radio frequency interference). RFI, as its name suggests, creates static on your radio and interference with other electronic equipment, including the vehicle’s on-board electronic control units (ECUs).
Resistor plugs were developed in the 1960s to suppress some of the spark energy, thus lowering RFI to an acceptable level. Most resistor spark plugs use a monolithic resistor, generally made of graphite and glass materials, to filter the electrical voltage as it passes through the center electrode.
Since resistor type plugs actually “resist” some of the spark energy, non-resistor type plugs actually deliver a more powerful spark. It is for this reason that most racing plugs are non-resistor types. However, in most automotive applications, a resistor plug is required for proper vehicle operation. Use of non-resistor plugs in vehicles that call for a resistor type can result in rough idling, high-rpm misfire, and abnormal combustion.
Re: Who sells NGK BCP6ES? [Re: 70sixpkrt] #3145697
05/20/23 02:42 AM
05/20/23 02:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You can buy direct from NGKs website if they have them:
https://www.ngk.com/ngk-4930-bcp6es-nickel-spark-plug
Says Discontinued, and to use NGK 2330
https://www.ngk.com/ngk-2330-bcpr6es-nickel-spark-plug
Re: Who sells NGK BCP6ES? [Re: A12] #3145709
05/20/23 06:14 AM
05/20/23 06:14 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
As you increase the ohmic resistance of the sparking system,
either by adding a resistor to the spark plug
or adding resistance to the wire,
the “burn time” of the spark increases.
Having a very intense spark with high current but for very short time,
by experiment has been found to result in more “misfires.”
Lowest misfire rate happens at the compromise where the spark intensity is “good enough” and when the time the spark endures is relatively long,
by experiment has been found to result in lowest possible misfires rate,
At high rpm a single coil does not have time to “recover” before the next cylinder fires.
Misfire rate at high rpm can be reduced at by having a coil for each cylinder.
Misfire rate can be further reduced by having two (or more) spark plugs per cylinder, each with its own coil.
( 5.7 Hemi set up)
Seems excessively crazy,
but an MIT student wrote his Master’s thesis about finding how many spark plugs per cylinder were needed to reduce the misfire rate to zero.
He got up to 16 spark plugs on a single cylinder and was still finding improvement.
The single cylinder, variable compression ratio, side valve design, CFR engine he was using has a combustion chamber design that lacks modern “overhead valve” engine design with quench, swirl, or tumble.
Re: Who sells NGK BCP6ES? [Re: 360view] #3145729
05/20/23 09:38 AM
05/20/23 09:38 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
( 5.7 Hemi set up)
Your MIT example negates your increased resistance claim.
As you add resistance in parallel ( more plugs in this case) over all resistance drops.
You need to cite both claims to make a coherent conclusion.
