Re: Who sells NGK BCP6ES?
[Re: 70sixpkrt]
#3145063
05/17/23 12:01 AM
05/17/23 12:01 AM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
I did and a lot of websites says discontinued. Yep, almost all or everyone that I searched (Amazon, ebay, motorcycle, ATV parts distributors, etc.,) say NOT AVAILABLE??
[Re: A12]
#3145092
05/17/23 08:50 AM
05/17/23 08:50 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i just bought 8 yesterday from Advanced Auto.They were in stock.
[Re: larrymopar360]
#3145295
05/18/23 11:14 AM
05/18/23 11:14 AM
Posts: 4,575 Motor City
6PKRTSE
Motor City
Superceded to a 2330 stock number. Same plug.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: A12]
#3145346
05/18/23 02:21 PM
05/18/23 02:21 PM
A12
N.E. OHIO, USA
WHAT IS A RESISTOR SPARK PLUG? Spark Plug Resistor Location
At the moment the spark jumps the gap it causes a high frequency burst of energy, known as RFI (radio frequency interference). RFI, as its name suggests, creates static on your radio and interference with other electronic equipment, including the vehicle’s on-board electronic control units (ECUs).
Resistor plugs were developed in the 1960s to suppress some of the spark energy, thus lowering RFI to an acceptable level. Most resistor spark plugs use a monolithic resistor, generally made of graphite and glass materials, to filter the electrical voltage as it passes through the center electrode.
Since resistor type plugs actually “resist” some of the spark energy, non-resistor type plugs actually deliver a more powerful spark. It is for this reason that most racing plugs are non-resistor types. However, in most automotive applications, a resistor plug is required for proper vehicle operation. Use of non-resistor plugs in vehicles that call for a resistor type can result in rough idling, high-rpm misfire, and abnormal combustion.
[Re: A12]
#3145709
05/20/23 06:14 AM
05/20/23 06:14 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
As you increase the ohmic resistance of the sparking system, either by adding a resistor to the spark plug or adding resistance to the wire, the “burn time” of the spark increases.
Having a very intense spark with high current but for very short time, by experiment has been found to result in more “misfires.”
Lowest misfire rate happens at the compromise where the spark intensity is “good enough” and when the time the spark endures is relatively long, by experiment has been found to result in lowest possible misfires rate,
At high rpm a single coil does not have time to “recover” before the next cylinder fires. Misfire rate at high rpm can be reduced at by having a coil for each cylinder.
Misfire rate can be further reduced by having two (or more) spark plugs per cylinder, each with its own coil. ( 5.7 Hemi set up)
Seems excessively crazy, but an MIT student wrote his Master’s thesis about finding how many spark plugs per cylinder were needed to reduce the misfire rate to zero. He got up to 16 spark plugs on a single cylinder and was still finding improvement. The single cylinder, variable compression ratio, side valve design, CFR engine he was using has a combustion chamber design that lacks modern “overhead valve” engine design with quench, swirl, or tumble.
[Re: 360view]
#3145729
05/20/23 09:38 AM
05/20/23 09:38 AM
Posts: 6,291 nowhere
Sniper
nowhere
Seems excessively crazy, but an MIT student wrote his Master’s thesis about finding how many spark plugs per cylinder were needed to reduce the misfire rate to zero. He got up to 16 spark plugs on a single cylinder and was still finding improvement. The single cylinder, variable compression ratio, side valve design, CFR engine he was using has a combustion chamber design that lacks modern “overhead valve” engine design with quench, swirl, or tumble. Your MIT example negates your increased resistance claim. As you add resistance in parallel ( more plugs in this case) over all resistance drops. You need to cite both claims to make a coherent conclusion.
