Which Wheel Nuts #3145592
05/19/23 02:52 PM
05/19/23 02:52 PM
London, England
JFChallenger440 Offline OP
London, England
Please can anyone let me know which wheel nuts I need for the steel wheels with dog dish caps ?
If on this link please let me know which ones
Many thanks
https://www.northhantstyres.com/wheel-nuts-and-bolts.php
Re: Which Wheel Nuts [Re: JFChallenger440] #3145596
05/19/23 03:14 PM
05/19/23 03:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Acorn - but.....
You did not mention car type, model year or if studs are all RH or a mix of RH / LH thread?
Re: Which Wheel Nuts [Re: Alaskan_TA] #3145599
05/19/23 04:10 PM
05/19/23 04:10 PM
London, England
London, England
Sorry , 69 Coronet
All RH thread
They do 2 types of acorn though ? Thanks
Re: Which Wheel Nuts [Re: JFChallenger440] #3145604
05/19/23 04:30 PM
05/19/23 04:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Open end with steelies & caps.
The others are for optional styled Road and Rallye wheels.
Re: Which Wheel Nuts [Re: Alaskan_TA] #3145608
05/19/23 04:40 PM
05/19/23 04:40 PM
London, England
London, England
Ok cool
Thanks for your help
Re: Which Wheel Nuts [Re: JFChallenger440] #3145637
05/19/23 06:39 PM
05/19/23 06:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thread will be 1/2 - 20 with the stock studs, and require either a 3/4" or 13/16" socket.
Re: Which Wheel Nuts [Re: Alaskan_TA] #3145647
05/19/23 07:30 PM
05/19/23 07:30 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
OR 69-1/2 A12 CARS grin
Re: Which Wheel Nuts [Re: A12] #3146005
05/21/23 02:32 PM
05/21/23 02:32 PM
London, England
London, England
2 options here , how do I know if I need 3/4” or 13/16” ? Thanks
Re: Which Wheel Nuts [Re: JFChallenger440] #3146165
05/22/23 12:39 PM
05/22/23 12:39 PM
moparx Offline
moparx  Offline
almost all chrysler products used 3/4" hex nuts. ford used the 13/16" hex.
way back in my junkyard days, it was apparent air wrenches would over tighten the lugnuts, and somewhat make the wheel hole try to swallow the nut.
we used the ford nuts to give a little extra contact area to secure the wheel.
the only drawback to that, ford never used left hand nuts, so this was limited to be used on 71 [?] and up.
beer
Re: Which Wheel Nuts [Re: moparx] #3146169
05/22/23 12:50 PM
05/22/23 12:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dont forget Imperials My 66 had like 15/16 lugs the 69 70s hard 13/16 Every other mopar I had were all 3/4
Chrysler Firepower
Re: Which Wheel Nuts [Re: therocks] #3146173
05/22/23 01:14 PM
05/22/23 01:14 PM
moparx Offline
moparx  Offline
right rocky. i left the imperials out, because most here will be doing just a, b, and c bodies.
the 3/4 ton pickups with the 8 bolt wheels also used 13/16" nuts if i remember right.
beer
Re: Which Wheel Nuts [Re: moparx] #3146214
05/22/23 04:55 PM
05/22/23 04:55 PM
London, England
London, England
So I’ll be ok with the 3/4” Hex ones ?
These are my wheels holes
url=https://postimages.org/][Linked Image][/url]
Re: Which Wheel Nuts [Re: JFChallenger440] #3146344
05/23/23 09:29 AM
05/23/23 09:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Should be thats what factory used.The steel wheels do have the holes open a bit after lots of use Never had a problem though
Chrysler Firepower
Re: Which Wheel Nuts [Re: therocks] #3146350
05/23/23 09:58 AM
05/23/23 09:58 AM
Maryland
mrob Offline
mrob  Offline
Maryland
If the lug nut holes are worn from use, you can use 60 degree tapered bulge seat lug nuts like these:
https://www.summitracing.com/parts/rnb-611-154
They're also available as acorn lug nuts. hope this helps.
Re: Which Wheel Nuts [Re: mrob] #3146374
05/23/23 12:27 PM
05/23/23 12:27 PM
moparx Offline
moparx  Offline
i was going to suggest those bulge seat nuts as well.
no one will know if you are using a wheel cover or hub cap.
beer
