82 F250 quit running suddenly
#3145602
05/19/23 04:23 PM
05/19/23 04:23 PM
Posts: 19,895 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
400 V8, if it matters. Was sitting at idle, running beautifully as usual, and it gave a quick sputter (maybe 2 seconds) and died. Cranks and sputters, won't start. Entire engine is new inside and out, even the carb and distributor are new. However, I reused the coil (cheapskate lol), and did not replace the electronic ignition module. I'm thinking that the module is the most likely culprit, since it is original. A module is $30 from Rock Auto, and a coil is $10. I figured I'd replace them both like I should have anyway, but what say ye about what's the most likely cause? I thought module, coil, fuel pump, in that order. It's definitely not out of fuel. I even tried switching from the front tank to the rear tank, would still not start.
Earning every penny of that moderator paycheck.
DBAP
Re: 82 F250 quit running suddenly
[Re: not_a_charger]
#3145611
05/19/23 04:49 PM
05/19/23 04:49 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
400 V8, if it matters. Was sitting at idle, running beautifully as usual, and it gave a quick sputter (maybe 2 seconds) and died. Cranks and sputters, won't start. Entire engine is new inside and out, even the carb and distributor are new. However, I reused the coil (cheapskate lol), and did not replace the electronic ignition module. I'm thinking that the module is the most likely culprit, since it is original. A module is $30 from Rock Auto, and a coil is $10. I figured I'd replace them both like I should have anyway, but what say ye about what's the most likely cause? I thought module, coil, fuel pump, in that order. It's definitely not out of fuel. I even tried switching from the front tank to the rear tank, would still not start. I"d start by checking for fuel and then for spark. I'd lean towards spark being the problem and especially suspicious of the module.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: not_a_charger]
#3145615
05/19/23 04:55 PM
05/19/23 04:55 PM
3hundred
Colleyville
Module is original. No idea why I didn’t change it when the engine went in. 😬 There was no need, it took decades to beat the idea into my head, if it ain't broke don't fix it. Except for water pumps that have been off and dried out, those get scrapped. I put too many back that leaked shortly afterwards. I'd rather have an OEM fomoco module than a chineseum one.
[Re: not_a_charger]
#3145616
05/19/23 04:57 PM
05/19/23 04:57 PM
Posts: 21,505 N.E. OHIO, USA
A12
N.E. OHIO, USA
Module is original. No idea why I didn’t change it when the engine went in. 😬 So you confirmed you do not have spark??
[Re: not_a_charger]
#3145649
05/19/23 07:36 PM
05/19/23 07:36 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Of course any complaint of crank-no-start should begin with a fuel/spark diagnostic branch: Is there a strong, intact squirt of fuel generated from the accelerator pump when the throttle is cycled? What does the spark look like when asked to jump a gap between the coil wire and an engine ground? The next list is highly UNscientific, and merely percentage bets, accumulated from spending a few years in an automotive electric shop in the early 80's. The most-failed component in early electronic ignition systems: GM/HEI - cap and/or rotor Mopar - ballast resister Ford - control box
Down to just a blue car now.
[Re: topside]
#3145657
05/19/23 08:16 PM
05/19/23 08:16 PM
Posts: 1,821 South Bend
John Brown
South Bend
IIRC, the spark box was a finned aluminum deal; they could be trouble-prone. I recall replacing one ago on a buddy's '79 Ford Ranchero. Same symptoms, and I don't recall anything visual like leaked potting material. "EEC-IV" (IV as in 4) comes to mind...
A LOT of water's passed under the bridge since then, so I could be off on the Gen 4 nomenclature. Best way to identify the aluminum box type modules is by the color of the plastic where the wires go into the box. Don't let anyone try to sell you a box that has a different color cause it won't have the same plug ins.
[Re: Kudakidd]
#3145706
05/20/23 05:31 AM
05/20/23 05:31 AM
Posts: 5,807 ohio
ruderunner
ohio
Coils and fuel pumps tend to cause symptoms long before outright failure. Modules are like light bulbs, they work until they don't.
Angry white pureblood male
[Re: not_a_charger]
#3145732
05/20/23 09:45 AM
05/20/23 09:45 AM
Posts: 6,240 nowhere
Sniper
nowhere
It’s not Chinese. It’s the original box. One that has lasted 30+ years and commenters are complaining that they are unreliable, lol. Since you did zero troubleshooting no one is able to offer a cogent response other than to say the abrupt shutdown points to something in the ignition circuit, it could even be a fuse.
[Re: Sniper]
#3145845
05/20/23 05:05 PM
05/20/23 05:05 PM
Posts: 5,807 ohio
ruderunner
ohio
It’s not Chinese. It’s the original box. One that has lasted 30+ years and commenters are complaining that they are unreliable, lol. Since you did zero troubleshooting no one is able to offer a cogent response other than to say the abrupt shutdown points to something in the ignition circuit, it could even be a fuse. You don't read so well do ya? We're telling him not to buy cheap crappy import replacement parts. We didn't say the original was garbage.
[Re: ruderunner]
#3145851
05/20/23 05:26 PM
05/20/23 05:26 PM
Sniper
nowhere
It’s not Chinese. It’s the original box. One that has lasted 30+ years and commenters are complaining that they are unreliable, lol. Since you did zero troubleshooting no one is able to offer a cogent response other than to say the abrupt shutdown points to something in the ignition circuit, it could even be a fuse. You don't read so well do ya? We're telling him not to buy cheap crappy import replacement parts. We didn't say the original was garbage. people have said the OEM on fails easily as well. I will quote for your edification. IIRC, the spark box was a finned aluminum deal; they could be trouble-prone. I recall replacing one decades ago on a buddy's '79 Ford Ranchero. Same symptoms, and I don't recall anything visual like leaked potting material. "EEC-IV" (IV as in 4) comes to mind...
[Re: topside]
#3145939
05/21/23 06:40 AM
05/21/23 06:40 AM
Posts: 5,807 ohio
ruderunner
ohio
Yeah, big difference between likely failure and all junk.
That said, avoiding a no name replacement is the best bet.
