82 F250 quit running suddenly #3145602
05/19/23 04:23 PM
05/19/23 04:23 PM
Puttin' on the foil in Charles...
not_a_charger Offline OP
Mr. Big Shot Moparts Moderator
400 V8, if it matters. Was sitting at idle, running beautifully as usual, and it gave a quick sputter (maybe 2 seconds) and died. Cranks and sputters, won't start. Entire engine is new inside and out, even the carb and distributor are new. However, I reused the coil (cheapskate lol), and did not replace the electronic ignition module. I'm thinking that the module is the most likely culprit, since it is original. A module is $30 from Rock Auto, and a coil is $10. I figured I'd replace them both like I should have anyway, but what say ye about what's the most likely cause? I thought module, coil, fuel pump, in that order. It's definitely not out of fuel. I even tried switching from the front tank to the rear tank, would still not start.
Earning every penny of that moderator paycheck.
DBAP
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145611
05/19/23 04:49 PM
05/19/23 04:49 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I"d start by checking for fuel and then for spark. I'd lean towards spark being the problem and especially suspicious of the module.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 82 F250 quit running suddenly [Re: 3hundred] #3145612
05/19/23 04:52 PM
05/19/23 04:52 PM
Module is original. No idea why I didn’t change it when the engine went in. 😬
DBAP
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145615
05/19/23 04:55 PM
05/19/23 04:55 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
There was no need, it took decades to beat the idea into my head, if it ain't broke don't fix it. Except for water pumps that have been off and dried out, those get scrapped. I put too many back that leaked shortly afterwards. I'd rather have an OEM fomoco module than a chineseum one.
'69 300 Convertible
'16 300 S Hemi
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145616
05/19/23 04:57 PM
05/19/23 04:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
So you confirmed you do not have spark??
Re: 82 F250 quit running suddenly [Re: A12] #3145631
05/19/23 06:00 PM
05/19/23 06:00 PM
No, I haven’t messed with it yet at all. I left it where it died. I’ll horse around with it tomorrow.
DBAP
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145640
05/19/23 06:53 PM
05/19/23 06:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
IIRC, the spark box was a finned aluminum deal; they could be trouble-prone.
I recall replacing one decades ago on a buddy's '79 Ford Ranchero.
Same symptoms, and I don't recall anything visual like leaked potting material.
"EEC-IV" (IV as in 4) comes to mind...
A LOT of water's passed under the bridge since then, so I could be off on the Gen 4 nomenclature.
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145649
05/19/23 07:36 PM
05/19/23 07:36 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Of course any complaint of crank-no-start should begin with a fuel/spark diagnostic branch:
Is there a strong, intact squirt of fuel generated from the accelerator pump when the throttle is cycled?
What does the spark look like when asked to jump a gap between the coil wire and an engine ground?
The next list is highly UNscientific, and merely percentage bets, accumulated from spending a few years in an automotive electric shop in the early 80's.
The most-failed component in early electronic ignition systems:
GM/HEI - cap and/or rotor
Mopar - ballast resister
Ford - control box
twocents
Down to just a blue car now.
Re: 82 F250 quit running suddenly [Re: topside] #3145657
05/19/23 08:16 PM
05/19/23 08:16 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I recall replacing one ago on a buddy's '79 Ford Ranchero.
Best way to identify the aluminum box type modules is by the color of the plastic where the wires go into the box. Don't let anyone try to sell you a box that has a different color cause it won't have the same plug ins.
Re: 82 F250 quit running suddenly [Re: John Brown] #3145676
05/19/23 10:03 PM
05/19/23 10:03 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
I'm leaning towards fuel pump. DAMHIK New Carters from Rockauto are $18! Pushrod length is 2.20 if memory serves me.
Re: 82 F250 quit running suddenly [Re: Kudakidd] #3145706
05/20/23 05:31 AM
05/20/23 05:31 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Coils and fuel pumps tend to cause symptoms long before outright failure. Modules are like light bulbs, they work until they don't.
Angry white pureblood male
Re: 82 F250 quit running suddenly [Re: 3hundred] #3145708
05/20/23 06:05 AM
05/20/23 06:05 AM
So much helpful info here. Thank you all very much. cool
DBAP
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145711
05/20/23 07:18 AM
05/20/23 07:18 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi , As stated above , the color of the Wire Grommet on your ORIGINAL Ignition Module Box should have been Blue . Fold had multiple Grommet Colors for Different engines + Setups . NO idea what color Your Chinese Box Grommet Color is . The 1 in My 1984 Died on me at a Gas station . Truck Running Perfect , Pulled in to get gas , Shut off my Truck . Go to Restart , Nothing . Crank , Crank , Crank . I said Great , just like My MOPARS with the Ballasts . drive Get a Ford Box , NO Chinesium . Ronnie
Re: 82 F250 quit running suddenly [Re: 1969ronnie] #3145722
05/20/23 09:15 AM
05/20/23 09:15 AM
It’s not Chinese. It’s the original box.
DBAP
Re: 82 F250 quit running suddenly [Re: not_a_charger] #3145732
05/20/23 09:45 AM
05/20/23 09:45 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
One that has lasted 30+ years and commenters are complaining that they are unreliable, lol.
Since you did zero troubleshooting no one is able to offer a cogent response other than to say the abrupt shutdown points to something in the ignition circuit, it could even be a fuse.
Re: 82 F250 quit running suddenly [Re: Sniper] #3145749
05/20/23 10:59 AM
05/20/23 10:59 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Years ago I drove a Ford van into the shop...lifted it up and did a trans service. Lowered it back down, filled the trans, went to start it and....no start. Needed an ignition module. wrench
Re: 82 F250 quit running suddenly [Re: Sniper] #3145845
05/20/23 05:05 PM
05/20/23 05:05 PM
ohio
ohio
You don't read so well do ya?
We're telling him not to buy cheap crappy import replacement parts. We didn't say the original was garbage.
Re: 82 F250 quit running suddenly [Re: ruderunner] #3145851
05/20/23 05:26 PM
05/20/23 05:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
people have said the OEM on fails easily as well. I will quote for your edification.
Quote
Re: 82 F250 quit running suddenly [Re: Sniper] #3145865
05/20/23 06:21 PM
05/20/23 06:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That was my response to the question.
Yes, they could be trouble-prone back in the day - went through it.
Similar to the way Mopar ballast resistors have had issues; they don't all fail, obviously, but there's a history of such.
I don't know how you extrapolated my comments into "they're junk" or whatever.
I was merely and obviously relating known history and suggesting where to look for the OP's problem.
"Sniper"...aptly named...
Re: 82 F250 quit running suddenly [Re: topside] #3145939
05/21/23 06:40 AM
05/21/23 06:40 AM
ohio
ohio
Yeah, big difference between likely failure and all junk.
That said, avoiding a no name replacement is the best bet.
