slant 6 vs. 318 bellhousing interchange? #3145166
05/17/23 04:07 PM
05/17/23 04:07 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, is a /6 and small block V8 bellhousing pattern the same?
I have a 67 D200 4 door that had a 318 and 4 speed. But they are gone and I'd like to get the truck back on the road.
For donors, I have a granny gear 4 speed and slant 6 in an old junk 66 D300, and a 318/ automatic in a junk 67 Belvedere. I was thinking the 318 from the Belevdere and the bellhousing and trans from the D300 could go into the 67 D200. Will it work?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: slant 6 vs. 318 bellhousing interchange? [Re: Hemi_Joel] #3145170
05/17/23 04:18 PM
05/17/23 04:18 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
no unfortunately two totally different bellhousing patterns . this is one area mopar could have followed chevys lead in that straight six thru small and bigblock all interchange.
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: slant 6 vs. 318 bellhousing interchange? [Re: jwilson 61] #3145237
05/17/23 10:41 PM
05/17/23 10:41 PM
Minnesota
Minnesota
Thanks for the info!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: slant 6 vs. 318 bellhousing interchange? [Re: Hemi_Joel] #3145241
05/17/23 11:08 PM
05/17/23 11:08 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Your bellhousing should look something like this, they mount to the frame...
JB Rhinehart, Realist
A-Body's RULE!
Re: slant 6 vs. 318 bellhousing interchange? [Re: Rhinodart] #3145245
05/17/23 11:15 PM
05/17/23 11:15 PM
Minnesota
Minnesota
Rhino, years back I put a clutch in that 66 d300 slanty that is now a parts truck. I remember the bellhousing mounting to the frame, just like you say.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: slant 6 vs. 318 bellhousing interchange? [Re: Hemi_Joel] #3145255
05/18/23 01:31 AM
05/18/23 01:31 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have seen some early bellhousings for the heavy duty 4 speed that had both patterns on them. It's the one you had to unbolt the flywheel to get to all the bellhousing bolts.
Re: slant 6 vs. 318 bellhousing interchange? [Re: Hemi_Joel] #3145258
05/18/23 02:02 AM
05/18/23 02:02 AM
SB and slant six bolt patterns on the block are like Ford and I.H.. no were near the same whiney shruggy
Re: slant 6 vs. 318 bellhousing interchange? [Re: slantzilla] #3145384
05/18/23 07:05 PM
05/18/23 07:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
This is correct, do not conflate truck and car stuff, especially in that era. Flywheel is probably different though. The HD trans you mentioned is the NP435.
But if I recall correctly, and the last one I did was in the 90's so it's fuzzy, there is an adapter plate between the slant and the bellhousing?
I don't have a truck parts manual, but it should confirm the same bell for small block and /6. No idea what the big block trucks used though
Re: slant 6 vs. 318 bellhousing interchange? [Re: Sniper] #3145410
05/18/23 08:37 PM
05/18/23 08:37 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
There was an adapter plate that allowed small block 727 to bolt to a slant. Used a few years in early mid 60s until mopar started making slant 727 cases.
Don't know of anything for manuals though.
Angry white pureblood male
