Tuff wheel/Rim blow combo #3144351
05/13/23 10:57 AM
05/13/23 10:57 AM
MD
RTSE4ME Online content OP
RTSE4ME  Online Content OP
MD
I am installing a new Tuff wheel to replace worn and cracked rim blow. I was looking at the rim blow horn button and
thought this looks nice compIared to the tuff wheel horn button.It looks like it would fit with a little modifying to the button retainer but might leave a gap when I mocked it up on my desk
I have a friend who has a 3D printer that could make me a spacer to fill the gap or print a shorter retainer.
Anyone do something like this combo? How did you adapt the rim blow horn button. I can't be the only person.
Re: Tuff wheel/Rim blow combo [Re: RTSE4ME] #3144355
05/13/23 11:07 AM
05/13/23 11:07 AM
MD
MD
pic
Re: Tuff wheel/Rim blow combo [Re: RTSE4ME] #3144398
05/13/23 02:17 PM
05/13/23 02:17 PM
moparx Offline
moparx  Offline
any pictures of the underside of the horn cap and the switch mechanism ?
and by chance, did you ask me about machining an adapter for that at one time ?
someone did, but i lost the contact info.......... spank
beer
Re: Tuff wheel/Rim blow combo [Re: moparx] #3144404
05/13/23 02:45 PM
05/13/23 02:45 PM
MD
MD
i was thinking I could use my crush can since I am using a tuff wheel adapter now. I will cut off a ring it is about the same diameter as horn cap.Wish I had a band saw
I never asked you about an adapter
Re: Tuff wheel/Rim blow combo [Re: RTSE4ME] #3144426
05/13/23 05:37 PM
05/13/23 05:37 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Didn’t the rimblow get the horn button on wheel instead on center, hence why it calls “rimblow”?
The rimblow center cap is not a button per se, so is made to fit againts the wheel just as a finish cap. Wheel retainer and cap are made to fit tight without a gap. Being just need to cover the retainer itself is a low profile cap.
Now the tuff wheel center cap is higher to cover all around the button switch assembly and still being higher it gets a gap to clear the button function when pressing in againts the wheel.
Tuff wheel and rimblow wheel can be used indistinctly on any of the adapters, collapsible or not. But if working on an E body, I wouldn’t replace the collapsible unit. The regular “flat” spacer will make fit the wheel closer to the dash pad and your hands/fingers can meet with it. I have seen that happening on a friend’s 70 Cuda when installed a tuff wheel with the regular adapter.
Re: Tuff wheel/Rim blow combo [Re: NachoRT74] #3144448
05/13/23 07:36 PM
05/13/23 07:36 PM
MD
MD
Yipeee!!!!!!! Figured it out...Tuff wheel with rim blow horn cap.
Tuff wheel adapter fits perfect for the vertically handicap. E-body was made for it.
Re: Tuff wheel/Rim blow combo [Re: RTSE4ME] #3144501
05/14/23 02:47 AM
05/14/23 02:47 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Too close to the dash pad IMHO and dangerous while driving I think.
