Anyone want to guess what size width these wheels are ? #3143867
05/11/23 09:37 AM
05/11/23 09:37 AM
London, England
JFChallenger440 Offline OP
London, England
Hi
I’m trying to find the width of these rear wheels on my car, any markings have long been scratched off or faded so can’t tell what they are
Is there any way of knowing without taking the tire off ?
The tires are 275/60/15
Pretty sure they are either 15 x 8 or 15 x 10
Anyone want to guess ?
Many thanks
Re: Anyone want to guess what size width these wheels are ? [Re: JFChallenger440] #3143870
05/11/23 09:43 AM
05/11/23 09:43 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
You measure them pretty easily with a straight edge and tape measure.
Re: Anyone want to guess what size width these wheels are ? [Re: mopowers] #3143875
05/11/23 10:04 AM
05/11/23 10:04 AM
west palm beach, florida
modelmakerinc Offline
275s, not much bulge, 8" is likely at most no way 10"
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Anyone want to guess what size width these wheels are ? [Re: JFChallenger440] #3143880
05/11/23 10:38 AM
05/11/23 10:38 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
looks like a 8.5 this is my 10 with 4 7/8 back spacing
Re: Anyone want to guess what size width these wheels are ? [Re: mopowers] #3143884
05/11/23 11:26 AM
05/11/23 11:26 AM
iagree I use two carpenter squares laid on each side of the outer edge of the rims and measure them wrench scope up
Re: Anyone want to guess what size width these wheels are ? [Re: JFChallenger440] #3143892
05/11/23 11:51 AM
05/11/23 11:51 AM
central il.
second 70 Offline
second 70  Offline
central il.
Not 10
Re: Anyone want to guess what size width these wheels are ? [Re: second 70] #3143898
05/11/23 12:09 PM
05/11/23 12:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd say 8.0" maybe 8.5" - some wheels are only made in one or the other, or BS will tell you.
Not hard to measure mounted.
Re: Anyone want to guess what size width these wheels are ? [Re: topside] #3143912
05/11/23 01:13 PM
05/11/23 01:13 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Re: Anyone want to guess what size width these wheels are ? [Re: CSK] #3143921
05/11/23 01:41 PM
05/11/23 01:41 PM
London, England
London, England
Thanks for the replies
CSK what size tires are they ? Any pics of it on the ground ?
Re: Anyone want to guess what size width these wheels are ? [Re: Dcuda69] #3144032
05/11/23 10:02 PM
05/11/23 10:02 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
Originally Posted by Dcuda69
I was going to say, just take it to anywhere that balances tires and have them check it with their caliper. Wheel width is one of the 3 data entries you have to make when spin balancing...
Re: Anyone want to guess what size width these wheels are ? [Re: nuthinbutmopar] #3144043
05/11/23 10:35 PM
05/11/23 10:35 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'm going to say they are 10" wide if the bulge is about 1/2" to 9/16" past the rim edges.
Re: Anyone want to guess what size width these wheels are ? [Re: nuthinbutmopar] #3144045
05/11/23 10:45 PM
05/11/23 10:45 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I was going to post the same reply except many of the new balancers (like Hunter Road Force)no longer require the data entries....lasers measure it all for you so no calipers required. We have them at work...fantastic machines!!
Re: Anyone want to guess what size width these wheels are ? [Re: JFChallenger440] #3144053
05/11/23 11:20 PM
05/11/23 11:20 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This is with 325 50 15
Re: Anyone want to guess what size width these wheels are ? [Re: CSK] #3144055
05/11/23 11:21 PM
05/11/23 11:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
it now has 390 45 15
Re: Anyone want to guess what size width these wheels are ? [Re: CSK] #3144099
05/12/23 09:01 AM
05/12/23 09:01 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lay the tire on the ground. Put a straight edge across the sidewall. Measure from the ground. Now you have the sidewall width of the tire. Then measure down from the sidewall to the outer lip of the wheel using a straight edge. Take this measurement and multiply by 2. Then add 1". Then take that answer and subtract it from the tire sidewall number. Example: Tire sidewall measurement is 12". Sidewall to outer rim lip measurement is 1.5".
1.5 x 2 = 3 3 + 1 + 4 12 - 4 = 8 The edges of the rim vary som with different wheels. Measurements may be off by a 1/4" or so. But it'll be close enough to tell
Doug
