Anyone want to guess what size width these wheels are ?
#3143867
05/11/23 09:37 AM
05/11/23 09:37 AM
Posts: 234 London, England
JFChallenger440
London, England
Hi I’m trying to find the width of these rear wheels on my car, any markings have long been scratched off or faded so can’t tell what they are Is there any way of knowing without taking the tire off ? The tires are 275/60/15 Pretty sure they are either 15 x 8 or 15 x 10 Anyone want to guess ? Many thanks
Re: Anyone want to guess what size width these wheels are ?
[Re: JFChallenger440]
#3143880
05/11/23 10:38 AM
05/11/23 10:38 AM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
looks like a 8.5 this is my 10 with 4 7/8 back spacing
[Re: topside]
#3143912
05/11/23 01:13 PM
05/11/23 01:13 PM
Posts: 4,945 WI
Dcuda69
WI
[Re: nuthinbutmopar]
#3144045
05/11/23 10:45 PM
05/11/23 10:45 PM
Posts: 4,945 WI
Dcuda69
WI
I was going to say, just take it to anywhere that balances tires and have them check it with their caliper. Wheel width is one of the 3 data entries you have to make when spin balancing... I was going to post the same reply except many of the new balancers (like Hunter Road Force)no longer require the data entries....lasers measure it all for you so no calipers required. We have them at work...fantastic machines!!
#3144053
05/11/23 11:20 PM
05/11/23 11:20 PM
CSK
Pattison Texas
Thanks for the replies
CSK what size tires are they ? Any pics of it on the ground ?
Thanks This is with 325 50 15
[Re: CSK]
#3144099
05/12/23 09:01 AM
05/12/23 09:01 AM
Posts: 9,836 MI, usa
dvw
MI, usa
Lay the tire on the ground. Put a straight edge across the sidewall. Measure from the ground. Now you have the sidewall width of the tire. Then measure down from the sidewall to the outer lip of the wheel using a straight edge. Take this measurement and multiply by 2. Then add 1". Then take that answer and subtract it from the tire sidewall number. Example: Tire sidewall measurement is 12". Sidewall to outer rim lip measurement is 1.5". 1.5 x 2 = 3 3 + 1 + 4 12 - 4 = 8 The edges of the rim vary som with different wheels. Measurements may be off by a 1/4" or so. But it'll be close enough to tell Doug
