Sorry to ask this! #314402
05/11/09 04:41 AM
05/11/09 04:41 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I spent an hour or so looking through past archives and current pages and can't find the answer. So sorry to ask this again after the 1,000,000th time someone has probably asked, but what is the largest tire/wheel combo anyone has fit under a '69 Dart without tubs or moving the spirings?
Thanks in advance, and once again my apologies!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Sorry to ask this! [Re: OhioMopar] #314403
05/11/09 05:55 AM
05/11/09 05:55 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Re: Sorry to ask this! [Re: OhioMopar] #314404
05/11/09 08:08 AM
05/11/09 08:08 AM
Ask away. that's the whole purpose of this free (& excellent) site. Doesn't matter if it's a repeat as long as it(tech problems w multiple postings) are kept in the same thread & the solution is shared when it is finally solved )
Re: Sorry to ask this! [Re: OhioMopar] #314405
05/11/09 08:34 AM
05/11/09 08:34 AM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
Right now I'm running a 245/60-15 on the rear right now, and previously was running a 26x10.5. I have the wheelwell lips pounded flat, but have plenty of clearance. The 10.5 was tight, but fit in there nicely.
Darrah Heath
Re: Sorry to ask this! [Re: VT_Dart] #314406
05/12/09 03:36 AM
05/12/09 03:36 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Okay. Cool. Anyone else?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Sorry to ask this! [Re: OhioMopar] #314407
05/12/09 07:30 AM
05/12/09 07:30 AM
scratchnfotraction Offline
on my 68 Dart I ran the a-body 8 3/4 with the large brake offset on the axles with green bearings which made the whole rear axle about 1/2" wider than stock..1/4" each side,IIRC
I ran 245/60/15 on 7" rim with a 4.5 backspace
fit just right and tire was centerd in the stock wheel tub
I did not have to roll the lip on the fender
was a 1/8"-1/4" clearance on the tire bulge and spring pack
just remember to figure in the tire bulge when measuring the rim/tire combo
Re: Sorry to ask this! [Re: scratchnfotraction] #314408
05/13/09 04:10 AM
05/13/09 04:10 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Okay, will do. Thanks!
1969 Dart GTS 340
2015 Dodge Dart GT
