Aftermarket consoles #3143647
05/10/23 01:30 PM
05/10/23 01:30 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm thinking about buying an aftermarket console for my Dart and wanted to ask if anyone here has bought an aftermarket console (the type with the cup holders built in) for your Mopar and if so, how did it fit and look? I haven't found much specifically for Mopars but there are some for Mustangs and Corvairs that I thought might be narrow enough to fit in between the buckets in my Dart.
Re: Aftermarket consoles [Re: 6PAX] #3145288
05/18/23 10:31 AM
05/18/23 10:31 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Have you considered a clean center console from a more modern wrecked car at a pick and pull? The advantage is the quality would be high and you could do a quickie set it in visual mock up- and if you don't like it simply return it.
Keep old mopars alive.
Re: Aftermarket consoles [Re: 2boltmain] #3145396
05/18/23 07:52 PM
05/18/23 07:52 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
No, I hadn't thought of that. The thing is the console can't be very wide to fit in between my seats. I've only got about 7" seat to seat.
Re: Aftermarket consoles [Re: 6PAX] #3145470
05/19/23 12:34 AM
05/19/23 12:34 AM
New York
64 Sportfury Offline
New York
I used a 2014 Chrysler 200 console in my 68 Coronet wagon. I also used 2004 Altima buckets. The console almost looks like it was made to fit. I fabbed simple mounting brackets where it meets the bottom of the dash (metal) area and driveshaft hump.
Re: Aftermarket consoles [Re: 64 Sportfury] #3146008
05/21/23 02:40 PM
05/21/23 02:40 PM
GMP440 Offline
GMP440  Offline
The buckets and console look great. Might have to call this thread "modern console and bucket seats installed on a b-body done on a budget".
Re: Aftermarket consoles [Re: GMP440] #3147803
05/31/23 12:26 PM
05/31/23 12:26 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Do you have an original console? Are you looking for just a cup holder? If you have an original console you could make a cup holder insert for the bottom. You would need to make a latch to hold the lid open.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Aftermarket consoles [Re: 6PAX] #3147897
05/31/23 08:34 PM
05/31/23 08:34 PM
Any suggestions on who to buy a good reproduction 1969 A body 4 speed console and lid from? help
