Pinion snubber setting - #314335
05/11/09 01:33 AM
05/11/09 01:33 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
I fitted my adj pinion snubber and it makes contact with the floor pan even on the lowest setting.
I estimate theres about 3/16ths of crush from the "zero lash-just touching" position.
Not a huge amount but am I going to hurt the car by driving it with this setting, or will I just wear through snubbers more quickly?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Pinion snubber setting - [Re: Moparmal] #314336
05/11/09 02:45 AM
05/11/09 02:45 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Seriously ... the proper SETTING for a PS ....is sitting out by the dumpster. Just get some good springs on the car - SET the pinion angle down a tad ...and you are done with it.
If you are almost touching the floor with the PS now ... the car will not "hook" properly and it will look like a KANGEROO going down the track.
Re: Pinion snubber setting - [Re: dOc !] #314337
05/11/09 06:45 AM
05/11/09 06:45 AM
Moparmal Offline OP
Moparmal  Offline OP
Took it for a ride and you're not far wrong!! Hit a bump and it was most entertaining for a while....
Guess I'll get the springs re-set to provide some clearance, they need it anyway.
I run spring clamps as well, but I like the snubber for extra insurance.
Re: Pinion snubber setting - [Re: Moparmal] #314338
05/11/09 12:11 PM
05/11/09 12:11 PM
Toronto
mshred Offline
mshred  Offline
Toronto
whats wrong with the snubber setup? i was going to run heavy duty leafs with an adjustable snubber on my street/ strip car thinking it was going to help my traction.. atleast thats what the chassis manual tells me
Re: Pinion snubber setting - [Re: mshred] #314339
05/11/09 12:46 PM
05/11/09 12:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A PS was/is a bandaid for wornout springs. With the
springs you can today there's no reason for it. Also
do you see a race car with one? If you get that much
pinion wind up you need springs
Re: Pinion snubber setting - [Re: MR_P_BODY] #314340
05/11/09 05:21 PM
05/11/09 05:21 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
If you try an race with a snubber its prob gunna cause some problems. I dont no anything about using one on the street though.
Shawn Jennings
Re: Pinion snubber setting - [Re: Moparmal] #314341
05/11/09 05:55 PM
05/11/09 05:55 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Mal,i have the same problem on my Satellite.I have the mopar heavy duty rear springs and only have minimal clearance.
I fitted Rancho rear shocks and clamped the front half of the springs.I still have some tyre spin with or without the snubber-no you can't use it on the street.But i do have good seperation.
I may cut down the snubber body to give more clearance,i have the screw type from Mancini.
I am off to order adjustable front shocks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Pinion snubber setting - [Re: Moparmal] #314342
05/11/09 07:54 PM
05/11/09 07:54 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Wanna' build a budget set of SS springs ?
You can do-it for the cost of a sledge-hammer and two spare main leafs ! PUT that spare main leaf in ...minus the ends ...and "rebuild" it(with the sledge hammer) as the second leaf ...and "rebuild" the rest. After they are all together - CLAMP the front half and leave the rear-parts UNclamped. Then ... make sure you have a slight nose-down attitude of the pinion(with proper shims). GET the longest shocks you can ... a C body type will work .....
THERE you go.
Re: Pinion snubber setting - [Re: dOc !] #314343
05/12/09 04:27 AM
05/12/09 04:27 AM
Moparmal Offline OP
Moparmal  Offline OP
MSHRED - There's nothing wrong with a snubber as an "assist" to compensate - I ran one on my BW diff in the street for years but I had a decent amount of clearance. Its true they dont like bumps under WOT though....
Most guys don't use them because they can get SS springs and with fitted spring clamps theres no need for anything more.
Mr P Body - Im sorry but I dont reckon the snubber is any more a "band aid" than a spring clamp - its just a different way of doing things- I think I mentioned in another thread that the A Body SS springs don't fit our Chargers, so its clamps and a snubber for the short term unless I can get Doc to explain his spring modification....
Tex - You have an IM
Doc - You have me intrigued - how do the get the "ends" of the main leaf? - maybe I can make a up a stiffer right spring...... ..
Re: Pinion snubber setting - [Re: Moparmal] #314344
05/12/09 08:18 AM
05/12/09 08:18 AM
NJ
440challenger Offline
NJ
I run the snubber 1 inch from the floor pan with espo xhd springs unclamped rear and clamped front. car launches hard and straight. guess every setup is different though
Re: Pinion snubber setting - [Re: dOc !] #314345
05/12/09 08:42 AM
05/12/09 08:42 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
the correct setting is in the trash
Re: Pinion snubber setting - [Re: Moparmal] #314346
05/12/09 10:28 AM
05/12/09 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What he is referring to is using a double main leaf,
I use to do this years ago... just cut the eye off
the spring . I use to clamp a 3/8 thick steel plate
(same width as the spring)from the front eye to just
past the axle mounts
Re: Pinion snubber setting - [Re: MR_P_BODY] #314347
05/13/09 03:23 AM
05/13/09 03:23 AM
Moparmal Offline OP
Moparmal  Offline OP
OK thanks Mr P -
Where does the sledgehammer come in?
Re: Pinion snubber setting - [Re: Moparmal] #314348
05/13/09 03:27 AM
05/13/09 03:27 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
mal ... the S H ? ... to use to reshape the spring.
So ...what time and day is it in OZ ?
Re: Pinion snubber setting - [Re: dOc !] #314349
05/13/09 06:59 AM
05/13/09 06:59 AM
Moparmal Offline OP
Moparmal  Offline OP
Its now Wed night at 9pm,
Your tomorrow will be a fine day........
