Pinion snubber setting -
#314335
05/11/09 01:33 AM
05/11/09 01:33 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
I fitted my adj pinion snubber and it makes contact with the floor pan even on the lowest setting. I estimate theres about 3/16ths of crush from the "zero lash-just touching" position. Not a huge amount but am I going to hurt the car by driving it with this setting, or will I just wear through snubbers more quickly?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Pinion snubber setting -
[Re: dOoC]
#314337
05/11/09 06:45 AM
05/11/09 06:45 AM
Moparmal
Took it for a ride and you're not far wrong!! Hit a bump and it was most entertaining for a while....
Guess I'll get the springs re-set to provide some clearance, they need it anyway.
I run spring clamps as well, but I like the snubber for extra insurance.
[Re: mshred]
#314339
05/11/09 12:46 PM
05/11/09 12:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
whats wrong with the snubber setup? i was going to run heavy duty leafs with an adjustable snubber on my street/ strip car thinking it was going to help my traction.. atleast thats what the chassis manual tells me
A PS was/is a bandaid for wornout springs. With the springs you can today there's no reason for it. Also do you see a race car with one? If you get that much pinion wind up you need springs
[Re: MR_P_BODY]
#314340
05/11/09 05:21 PM
05/11/09 05:21 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
If you try an race with a snubber its prob gunna cause some problems. I dont no anything about using one on the street though.
Shawn Jennings
[Re: Moparmal]
#314341
05/11/09 05:55 PM
05/11/09 05:55 PM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
Mal,i have the same problem on my Satellite.I have the mopar heavy duty rear springs and only have minimal clearance. I fitted Rancho rear shocks and clamped the front half of the springs.I still have some tyre spin with or without the snubber-no you can't use it on the street.But i do have good seperation. I may cut down the snubber body to give more clearance,i have the screw type from Mancini. I am off to order adjustable front shocks Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Moparmal]
#314342
05/11/09 07:54 PM
05/11/09 07:54 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Wanna' build a budget set of SS springs ?
You can do-it for the cost of a sledge-hammer and two spare main leafs ! PUT that spare main leaf in ...minus the ends ...and "rebuild" it(with the sledge hammer) as the second leaf ...and "rebuild" the rest. After they are all together - CLAMP the front half and leave the rear-parts UNclamped. Then ... make sure you have a slight nose-down attitude of the pinion(with proper shims). GET the longest shocks you can ... a C body type will work .....
THERE you go.
[Re: dOoC]
#314343
05/12/09 04:27 AM
05/12/09 04:27 AM
Moparmal
MSHRED - There's nothing wrong with a snubber as an "assist" to compensate - I ran one on my BW diff in the street for years but I had a decent amount of clearance. Its true they dont like bumps under WOT though.... Most guys don't use them because they can get SS springs and with fitted spring clamps theres no need for anything more. Mr P Body - Im sorry but I dont reckon the snubber is any more a "band aid" than a spring clamp - its just a different way of doing things- I think I mentioned in another thread that the A Body SS springs don't fit our Chargers, so its clamps and a snubber for the short term unless I can get Doc to explain his spring modification.... Tex - You have an IM Doc - You have me intrigued - how do the get the "ends" of the main leaf? - maybe I can make a up a stiffer right spring...... ..
[Re: dOoC]
#314345
05/12/09 08:42 AM
05/12/09 08:42 AM
Posts: 799 north west LA
W2DODGE
north west LA
Seriously ... the proper SETTING for a PS ....is sitting out by the dumpster. Just get some good springs on the car - SET the pinion angle down a tad ...and you are done with it.
If you are almost touching the floor with the PS now ... the car will not "hook" properly and it will look like a KANGEROO going down the track.
the correct setting is in the trash
