Ladder bar question #3143043
05/07/23 02:45 PM
05/07/23 02:45 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
Inspected my ladder bars yesterday on the Valiant. Mine have a short adjustable link between the lower housing bracket eye and the bottom bar. I am guessing it is for setting pinion angle?
Thanks! wave
Re: Ladder bar question [Re: slantzilla] #3143059
05/07/23 03:31 PM
05/07/23 03:31 PM
birdtracker Offline
birdtracker  Offline
top is pinion angle. Birdtracker
Re: Ladder bar question [Re: birdtracker] #3143064
05/07/23 04:10 PM
05/07/23 04:10 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Front moves the IC, the bottom at the housing is for adding or removing preload.
Re: Ladder bar question [Re: Blusmbl] #3143081
05/07/23 06:19 PM
05/07/23 06:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Which does the same as ‘pinion’ angle..IF adjusted the same on both sides.
Re: Ladder bar question [Re: cudaman1969] #3143083
05/07/23 06:27 PM
05/07/23 06:27 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Set pinion angle with driver's side (left). Set preload with passenger side. (Right).
Re: Ladder bar question [Re: FastmOp] #3143112
05/07/23 10:18 PM
05/07/23 10:18 PM
Park Forest, IL
Park Forest, IL
Thanks for all the replies. I made sure to put everything back the way it was.
