Ladder bar question
#3143043
05/07/23 02:45 PM
05/07/23 02:45 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Inspected my ladder bars yesterday on the Valiant. Mine have a short adjustable link between the lower housing bracket eye and the bottom bar. I am guessing it is for setting pinion angle? Thanks!
Re: Ladder bar question
[Re: birdtracker]
#3143064
05/07/23 04:10 PM
05/07/23 04:10 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
Front moves the IC, the bottom at the housing is for adding or removing preload.
[Re: Blusmbl]
#3143081
05/07/23 06:19 PM
05/07/23 06:19 PM
Posts: 8,265 fredericksburg,va
cudaman1969
fredericksburg,va
Front moves the IC, the bottom at the housing is for adding or removing preload. Which does the same as ‘pinion’ angle..IF adjusted the same on both sides.
[Re: FastmOp]
#3143112
05/07/23 10:18 PM
05/07/23 10:18 PM
slantzilla
Park Forest, IL
Thanks for all the replies. I made sure to put everything back the way it was.
