Re: Ladder bar question
[Re: birdtracker]
#3143064
05/07/23 04:10 PM
05/07/23 04:10 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
Front moves the IC, the bottom at the housing is for adding or removing preload.
[Re: Blusmbl]
#3143081
05/07/23 06:19 PM
05/07/23 06:19 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
Front moves the IC, the bottom at the housing is for adding or removing preload. Which does the same as ‘pinion’ angle..IF adjusted the same on both sides.
