Page 2 of 3 1 2 3
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314305
05/11/09 09:46 PM
05/11/09 09:46 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
that should make some amazing bottom end torque with that throw. hmmm Mopar version of an Olds lol.
different means of getting to 572". sounds cools i went the normal 4.5x4.5
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314306
05/11/09 09:53 PM
05/11/09 09:53 PM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
Hey BIG CUBE..when i mock up the Block/Trans i am thinking i will be pushing the motor back about 3-4 inches at the most..help some on weight trasnfer and oilpan at the same time..ony have to modify the firewall some and a new trans crossmember..couple days and all will be fine...but if there is no clearance issues whn i fit the block in then motor will stay in factory location based on factory trans crossmember..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314307
05/12/09 09:28 AM
05/12/09 09:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
High compresion long stroke 572 + the motor moved back with a short wheelbase = big wheel stand. I would ask Greg where his motor is at. Considering this is a ladder bar car you can not move the I/C forward. At the very least I would think you would locate the motor as low as posible. Remember engine torque plays into planting the tire along with the wieght transfer.
Doug
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: dvw] #314308
05/12/09 10:17 AM
05/12/09 10:17 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Yea, I know.. Greg has moved his Motor Back farther than i ever will.. we have discussed that in great detail since i started the build.. he is waiting to see how my car hooks with the motor in stock location or only 3" back from there.. he was telling me that after he changed to the Indy block and changed the weight of the car it didnt hook as well as the iron block did. i think he is considering moving the motor back forward...i dont want to move but for the dragster pan to clear i may have to, but only a few inches..not 6 or a foot... i am very aware of the weight i took off the nose of my car.. instead of a Mega block weighing 295lbs and stock suspension..i took 100lbs off with the K-member and race brakes, and another 140+ by using the Indy block instaead of the Mega block.. the rest of the car is all steel..complete glass..but should still come in under 3K lbs..but thanks for the input...
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314309
05/12/09 10:48 AM
05/12/09 10:48 AM
gregsdart Offline
gregsdart  Offline
Billy, I must have said something that gave you the wrong info. I run a Mopar iron Megablock, and after the last chassis conversion to the full cage/17 inch setback it seemed to work well when running 9.50s, but more power put it over the edge resulting in too much weight transfer. After going over my info and looking at my data, the setback was already too much for the power I had at the 9.50 range. I think you have an ideal setup here, light block with the ability to move it back if you desire. It might actually be best to start with it in the reward most position, and adjust if needed?
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: gregsdart] #314310
05/12/09 11:52 AM
05/12/09 11:52 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
yea, thanks greg..i knew it was something like that.. it wont affect me that much..i just mis spoke without going back to look at the emails we sent.. i was thinking you changed blocks..the weight tansfer and engine set-up was it.. 17"..mine wont be more than 3-4 "Tops...no matter what..thanks again. guys..Getting really excited about finishing up this project..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314311
05/12/09 12:04 PM
05/12/09 12:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Is that a standard cam height block? I heard that with the 4.75 crank you had to watch cam/rod clearence. I am thinking of a similar combo.
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: B1MAXX] #314312
05/12/09 05:35 PM
05/12/09 05:35 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
it is a standard cam location Block..and yes, there is cam/rods clearence issues.. we mocked up the crank and one rod/piston, cam and timed it.. spun and checked where i needed to trim the shoulder of the rods..once i cleared one at .080 then i sent them off to all be done and rebalanced.. here are a few pics of the rods and how much i trimed..the machine shop rethreaded the rodbolts where i have shaved them down...
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314313
05/12/09 05:35 PM
05/12/09 05:35 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
two stacked on top of each other
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314314
05/12/09 05:36 PM
05/12/09 05:36 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
last one..these were before they went to the machine shop to be cleaned up...
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314315
05/14/09 06:36 PM
05/14/09 06:36 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Ok Guys..I gave you some wrong info the other day with the piston .001 in the hole.. after getting 2 pistons in the hole without rings to recheck everything i have .008 to the postive..and with "piston rock" it is close to .016-.017... so with what im being told about the Indy and other alum blocks there is some growth issues(.012-.015) as you do with alum rods..if this is the case then at opetating temp. i will be as close to "Zero Deck" as you can be... if this does not sound correct let me know..
Re: 572ci Motor for 63 INDY MAXX Dart( UPDATED PICS) [Re: BILLYJAY] #314316
05/31/09 07:56 PM
05/31/09 07:56 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Ok guys, i had to wait 2 weeks to get a chance to go work on my motor..we got the rings all file fit and on the pistons and insatlled the 8 slugs...will install the cam,timing chain and mock up heads next weekend ...here area few pics
Re: 572ci Motor for 63 INDY MAXX Dart( UPDATED PICS) [Re: BILLYJAY] #314317
05/31/09 07:57 PM
05/31/09 07:57 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
picture #2 4 down/4 to go...
Re: 572ci Motor for 63 INDY MAXX Dart( UPDATED PICS) [Re: BILLYJAY] #314318
05/31/09 07:58 PM
05/31/09 07:58 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
last 4 ..Yea....
Re: 572ci Motor for 63 INDY MAXX Dart( UPDATED PICS) [Re: BILLYJAY] #314319
05/31/09 07:59 PM
05/31/09 07:59 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
My cousin Tony.snugging down the rod bolts before torquing
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314320
05/31/09 08:00 PM
05/31/09 08:00 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
putting rings on the pistons..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314321
05/31/09 08:38 PM
05/31/09 08:38 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
Just a heads up you should double check rod clearance for each cylinder. On our 4.625 stroke mega block only 2 BME rids needed clearance. Can't remember off the top of my head which ones, but not all rods needed clearance and our clearance issues were with the cap and not the actual rod.
Sean
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: PlumCrazyCharger] #314322
05/31/09 09:31 PM
05/31/09 09:31 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
also check the pistons when they are at BDC. mine were hitting the block in the web
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: bigtimeauto] #314323
05/31/09 10:01 PM
05/31/09 10:01 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
thanks...We mocked up the crank and rods/pistons several months ago and clearanced them with about .090 to spare and it was only the shoulder of the rod that i had an issue with.. then sent them all off to be matched and rebalanced..when i bought the crank i had .180 cut off the OD of the counter weights..this is why my cousin is helping me with this build..i can build a motor but he is very anal about these motors and checking and rechecking..drives me crazy but it right when he builds them...he has a 557 Indy maxx motor.572-13 in a 91 Lebaron tube car..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314324
06/07/09 08:45 PM
06/07/09 08:45 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Cam installed, timing set,push-rod length checked and Valve To Piston clearanced...
Page 2 of 3 1 2 3
