Page 1 of 3 1 2 3
572ci Motor for 63 INDY MAXX Dart(UPDATED PICS) #314285
05/11/09 12:02 AM
05/11/09 12:02 AM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
well i finally got started on my 572ci Indy Maxx motor build this weekend..spent all day sat..washing, washing, and washing the Damn block..i have never seen some much alum shavings in a block before...Anyways Deburred everything,rifled brushed and Put the Mains in the freezer to get ready for crank installiation on Sunday..Anyone who doesnt believe that freezing these tight Indy mains doesnt work..should have been there with me today..they didnt just slid in but when in with very little tapping..when i mocked up the crank the first time to clearance the rods it was a pain in the butt..so anyways here are some pics..all rings have been file fit'd and Pistons/Rods are ready to install next weekend..
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314286
05/11/09 12:07 AM
05/11/09 12:07 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Bare Block cleaned
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314287
05/11/09 12:08 AM
05/11/09 12:08 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Main Studs installed
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314288
05/11/09 12:11 AM
05/11/09 12:11 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
crankshaft
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314289
05/11/09 12:12 AM
05/11/09 12:12 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Crankshaft with Mains..
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314290
05/11/09 12:13 AM
05/11/09 12:13 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
And of Course the tricky one....
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314291
05/11/09 12:13 AM
05/11/09 12:13 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Cap
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314292
05/11/09 12:14 AM
05/11/09 12:14 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Last one this week
Re: Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314293
05/11/09 07:22 AM
05/11/09 07:22 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
awesome! Looks amazing. have you mocked a BB in an early dart?
I was doing just the same thing until I realized I didn't have a rear main seal
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314294
05/11/09 07:28 AM
05/11/09 07:28 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
that looks nice...real nice...
have you weighed the car..
back in the day I had a 64 Dart GT...was light..I cant remember what it weighed but I think it was under 3,000lbs..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: smokinwoody] #314295
05/11/09 10:01 AM
05/11/09 10:01 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
I will be mocking A 440 short block that i have with a empty 727 trans case to weld in my motor plate tabs and to make sure the oil pan with clear the Magnum force K-Member..i know it is suppose to but sure doesnt look like it will..i have alread built and installed front pans and a New taller tunnel to clear my trans sheild..now i just need to make sure that i dont need to move the motor back about 3-4 inches at the most...The weight of the car should come in under 3K lbs.. Greg(greg's dart) has a 65 that race weight at 3002,2x3 tube chassis,9",ladder bars,indy block,pretty close to the same set-up and we have been doing alot of chatting over the past year,since i started the project..here are a couple more pics..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314296
05/11/09 10:02 AM
05/11/09 10:02 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
passenger side
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314297
05/11/09 10:10 AM
05/11/09 10:10 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
in the engine bay
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314298
05/11/09 10:11 AM
05/11/09 10:11 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
clearance view
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314299
05/11/09 11:14 AM
05/11/09 11:14 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
My Mega block was the same way. My only complaint about Indy was they sent the block with the oil galley plugs installed. It would be easy for a less experienced person to clean the block without removing those and thereby having a lot of metal in the system on the intitial start up.
Your car looks like a great project, and Greg seems to be an ideal person to be talking with. Good luck & keep the updates coming!
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: nhramark] #314300
05/11/09 08:46 PM
05/11/09 08:46 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Well my Indy Block came with a Plug kit..only thing that was on the block with the freeze plugs..my cousin has a Filter that he installed in the radiator hose on his Motor to help clean out the shavings..i will be doing the same with mine..
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: BILLYJAY] #314301
05/11/09 09:05 PM
05/11/09 09:05 PM
gregsdart Offline
gregsdart  Offline
Billy its looking great! I am excited to hear about the first passes. Care to share the motor specs with the gang?
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: gregsdart] #314302
05/11/09 09:24 PM
05/11/09 09:24 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
What are the details on the motor??
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: gregsdart] #314303
05/11/09 09:27 PM
05/11/09 09:27 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I had to notch the oil pan a lot when I had one of those FE on my car. Keep us posted on progress and keep the pics comming, looks nice so far
The screw in freeze plugs in a KB block were very helpful in flushing all the chips.. there were a lot!
Re: 572ci Motor Build for 63 INDY MAXX Dart [Re: gregsdart] #314304
05/11/09 09:33 PM
05/11/09 09:33 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
well no big secret..but kind of odd rotating assembly combo...started as 543ci and ended up finding a 4.75 crankshaft so i bought it and sold the 4.5 crank and rods..bought the 4.75 and then found a set of 7.0 chevy rods to work everything out..anyways ended up perfect...001 in the hole @TDC..4.380 bore with 4.75 stroke (572)with 7.0 rods and deck height at 10.720.. i am going to try a Rollercam that we had in one of our B-1 motors a few years ago..700/715 with 1.5 but have 1.6 now.my 440-1 heads are 345cc CND"d flowing 389@ .800 382 @ .700 and i am going to squeeze the [Edited by Moparts - Keep it clean] out of the motor with compression..was going to be around 13CR or so but am now going to get nearer to 15.5-16 if all goes well...i have a single Indy intake as well as a Indy tunnel ram intake both have been ported.. i have a 727 already built,manuel valve body 8" 5500 convertor,dana 60 with 4.30 spool and Hoosier 31x14x15...Im sure i forgot a few things but who dont?? ************************************************************* THE FLOWHEET IS THE ATTACHEMENT
Page 1 of 3 1 2 3
