Small Block Blower???
#314276
05/10/09 11:39 PM
05/10/09 11:39 PM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Looking for info on Blower/Screw/Roots style Superchargers for Small-Blocks. I know they have been done. I've seen a few Here & there. I just can't find a company that still carries the parts to for them. Especially the intake side. Any Help or Guidance would be appreciated.
Re: Small Block Blower???
[Re: DakFink]
#314277
05/11/09 01:36 AM
05/11/09 01:36 AM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Intakes are available, just not cheap. BDS sells them, for example. Also an Australian guy casts his own. Best plan is to buy a used one for about half of the ridiculous price BDS, INDY, etc charge. Drive is also a little problematic - meaning you can get it from the various blower shops, but they don't float around in the used market so much.
Good luck, Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: DakFink]
#314280
05/11/09 08:11 AM
05/11/09 08:11 AM
Posts: 9,847 MI, usa
dvw
MI, usa
Depends on quick you want to go. I have an old Dyers set-up. It's a 6-V71 mounted on a modified 4 barrel intake. motor is a 340+.030",245@.050" cam,ported stock heads,7.8-1 compression. With a 9" converter,4.30 gear,drag radials. 11.17@121 thru the mufflers in a 3850lb Volare. The blower is loose and worn beyond clearance specs. I run it 9% over at 12 lbs boost. Doug
[Re: MR_P_BODY]
#314282
05/11/09 09:31 AM
05/11/09 09:31 AM
Posts: 4,207 New York
polyspheric
New York
make a manifold for my 8-71 using a tunnel ram lower then weld a mounting plate to it
Better than almost all the commercial manifolds, too.
Boffin Emeritus
