Small Block Blower??? #314276
05/10/09 11:39 PM
05/10/09 11:39 PM
Texas Afghanistan Iraq etc.
DakFink Offline OP
DakFink  Offline OP
Looking for info on Blower/Screw/Roots style Superchargers for Small-Blocks.
I know they have been done. I've seen a few Here & there.
I just can't find a company that still carries the parts to for them. Especially the intake side.
Any Help or Guidance would be appreciated.
Re: Small Block Blower??? [Re: DakFink] #314277
05/11/09 01:36 AM
05/11/09 01:36 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Intakes are available, just not cheap.
BDS sells them, for example. Also an Australian guy casts his own.
Best plan is to buy a used one for about half of the ridiculous price BDS, INDY, etc charge.
Drive is also a little problematic - meaning you can get it from the various blower shops, but they don't float around in the used market so much.
Good luck,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: Small Block Blower??? [Re: kick_the_reverb] #314278
05/11/09 07:56 AM
05/11/09 07:56 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I just saw a new small block blower intake recently on ebay. It was priced pretty cheap. Don`t know if it sold or not. Mike
Re: Small Block Blower??? [Re: DakFink] #314279
05/11/09 08:06 AM
05/11/09 08:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm going to make a manifold for my 8-71 using a
tunnel ram lower then weld a mounting plate to it
Re: Small Block Blower??? [Re: DakFink] #314280
05/11/09 08:11 AM
05/11/09 08:11 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Depends on quick you want to go. I have an old Dyers set-up. It's a 6-V71 mounted on a modified 4 barrel intake. motor is a 340+.030",245@.050" cam,ported stock heads,7.8-1 compression. With a 9" converter,4.30 gear,drag radials. 11.17@121 thru the mufflers in a 3850lb Volare. The blower is loose and worn beyond clearance specs. I run it 9% over at 12 lbs boost.
Doug
Re: Small Block Blower??? [Re: dvw] #314281
05/11/09 08:12 AM
05/11/09 08:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A pic of the whole set-up
Re: Small Block Blower??? [Re: MR_P_BODY] #314282
05/11/09 09:31 AM
05/11/09 09:31 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Better than almost all the commercial manifolds, too.
Boffin Emeritus
Re: Small Block Blower??? [Re: DakFink] #314283
05/11/09 04:10 PM
05/11/09 04:10 PM
The centrifugal superchargers are a lot easier to find and install than the bigger ones that mount onto the intake manifolds, sneekier too
Re: Small Block Blower??? [Re: Cab_Burge] #314284
05/11/09 04:25 PM
05/11/09 04:25 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Around how much hp can you go on a 59* block with a blower before it gets scary?
