WIW, NOS manual steering box #3140014
04/22/23 04:55 PM
04/22/23 04:55 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I bought this many years ago, IIRC it's for a van but will also fit B bodies, but don't know that for a fact. I has what appears to be cracks, but they are from casting. The box is also supposed to hace the ball bearing in the cover, it's never been mounted.
Re: WIW, NOS manual steering box [Re: justinp61] #3140345
04/24/23 11:05 AM
04/24/23 11:05 AM
W. Kentucky
W. Kentucky
Bump.
Re: WIW, NOS manual steering box [Re: justinp61] #3140355
04/24/23 11:31 AM
04/24/23 11:31 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Quote
The compatibility problems with different boxes largely boils down to output shaft, or sector shaft size. First, there are two sector sizes, simply known as large or small sector. The large sector, just above the splines as it exits the housing, measures 1.22". The small sector measures 1.11".
62-76 A-bodies, 62-72 B-bodies, and 70-74 E-bodies all used the same manual box. Most of these boxes used bushings throughout, however, the B-body V-8 units were built for more abuse and used bearings internally instead of the bushings.
All manual boxes used a small sector shaft with the exception of C-bodies and vans to 1988. The big cars and vans used a large sector, presumably for added strength. It's also assumed these boxes used bearings instead of bushings.
from: https://www.forbbodiesonly.com/mopa...-steering-gear-box.165931/post-911156833, emphasis mine.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: WIW, NOS manual steering box [Re: Bob Stinson] #3140620
04/25/23 12:28 PM
04/25/23 12:28 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
How about shoe the top of the box???
And what is the casting date on the box?
Re: WIW, NOS manual steering box [Re: NANKET] #3140814
04/26/23 10:28 AM
04/26/23 10:28 AM
W. Kentucky
W. Kentucky
I'll have to check the casting date.
Re: WIW, NOS manual steering box [Re: justinp61] #3140866
04/26/23 02:54 PM
04/26/23 02:54 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
Years ago I had an NOS box that was for an F body.
It didn't have a box, it only had a parts tag wired to it. I was going to use it in a 70 Dart, till I found out about the large sector.
Re: WIW, NOS manual steering box [Re: NANKET] #3140919
04/26/23 09:23 PM
04/26/23 09:23 PM
W. Kentucky
W. Kentucky
I don't see any casting date,
Re: WIW, NOS manual steering box [Re: justinp61] #3140924
04/26/23 10:40 PM
04/26/23 10:40 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Box is dated 10-9-84 part is stamped 6-25-84. 4023 starting PN would fall into line as well. shruggy
Early 80-s truck/van?
Probably get $200
Screenshot 2023-04-26 at 20-51-19 04032101 - Dodge Gear manual steering gear steering Factory Chrysler Parts Bartow FL.png
STOP POTATO HATE!
Re: WIW, NOS manual steering box [Re: Mr PotatoHead] #3141436
04/29/23 11:15 PM
04/29/23 11:15 PM
IL
furious70 Offline
furious70  Offline
IL
yup that canted top plate tells you its a van/c body one. While not hugely sought after, $200-300 for one you know isn't worn out doesn't seem bad. I have a used one I was trying to get that range for and the guy said no thanks. I sold another one cheaper but to a friend. It was also used.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: WIW, NOS manual steering box [Re: furious70] #3141667
05/01/23 08:30 AM
05/01/23 08:30 AM
W. Kentucky
W. Kentucky
Thanks guys. up
