Re: 1970 Cuda Body Piece
[Re: jim6346]
#3139561
04/20/23 05:23 PM
04/20/23 05:23 PM
Posts: 8,288 fredericksburg,va
cudaman1969
fredericksburg,va
Floor pan I’m thinking, or the piece it’s welded to, you’ll have to make that up. I’ll look at my 72 later, only thing not replaced on it from rust is the roof, pass kick panel and rockers. Replaced with As many original pieces I could find (glad b-bodies are close)
[Re: FJ6AAR]
#3139577
04/20/23 06:21 PM
04/20/23 06:21 PM
Posts: 1,548 Mattituck NY.
FJ6AAR
Mattituck NY.
It connects to the rear part of the inner rocker to the outside part of the front part of the rear frame rail. It mounts right in front of the inner wheelhouse as it connects the inner rocker to the rear frame rail.. Hope this helps? Rob Here is another link for both Lh and Rh sides: https://www.ebay.com/itm/134514113263
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
[Re: jim6346]
#3140912
04/26/23 08:40 PM
04/26/23 08:40 PM
FJ6AAR
Mattituck NY.
Perfect, thank you!!
Ordered and in already.
Uphill battle, she has been out of commission since 1984 (wrecked)
You're welcome Jim, glad I could help.
