Best stroker kit for a 383/440? #3139172
04/19/23 01:39 AM
04/19/23 01:39 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Seems this belongs here.
I have been out of the game a fast ten years building a ranch in Idaho. Sold my cars and Cuda vert to pay for my out of pocket home build too. I have a 63 Sport fury vert I’m considering building and debating a modern Hemi VS a 383 or 440 stroker.
My last few kits were 440source but I recall hearing their quality dropped?
Plus after 10 years I’m sure there are new suppliers ect ???
Re: Best stroker kit for a 383/440? [Re: RUMBLON] #3139179
04/19/23 03:11 AM
04/19/23 03:11 AM
Try Ohio Crankshaft company for you parts, they make good stuff here in America up
I make my own kits using their crank and rods and either Ross or United Machine Icon forged pistons, AKA as KB, pistons up/If your wanting to build a motor with some power and want to rev it up regularly look for a 400 block instead of the 383 or 440 blocks, they both have real thin main webbing that will crack under medium to heavy duty use, the 400 blocks live a lot longer up
Re: Best stroker kit for a 383/440? [Re: Cab_Burge] #3139183
04/19/23 05:30 AM
04/19/23 05:30 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
As Cab says, the 400 block is your winner. I have a 512 & a 455 stroker 400, both are as good as each other although I rev the the 455 higher. If you go past 470 cubes you'll want to consider max wedge ports if you want to make real power, but a 500+ cube std port would make a zippy street car, just the top end will be lacking, but how often are you going to be maxed out on your rpm? I don't use Source parts, im a believer that you don't skimp on the spinning bits, if they fail, the costs are astronomical & it would have been cheaper to have bought real quality in the first place.
Re: Best stroker kit for a 383/440? [Re: rebel] #3139206
04/19/23 08:36 AM
04/19/23 08:36 AM
USA
hudsonhornet7x Offline
USA
I had a 470 built for my Charger. Used a Molnar crank with Eagle rods and Ross pistons. I also agree that the 400 is the best block to start with. As far as new hemi engines go, they are great but I feel it takes away some of the cars soul so to speak.
Re: Best stroker kit for a 383/440? [Re: hudsonhornet7x] #3139214
04/19/23 09:19 AM
04/19/23 09:19 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Our favorite is the 440 or 400 based 512 kit....These things make power
Re: Best stroker kit for a 383/440? [Re: Dragula] #3139222
04/19/23 09:48 AM
04/19/23 09:48 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
And there is absolutely no reason NOT to use the available Chevy 2.20 rod journal. My next build will be a 512/400 block combo, from Molnar.
69 GTX 68 Road Runner
Re: Best stroker kit for a 383/440? [Re: JERICOGTX] #3139225
04/19/23 10:14 AM
04/19/23 10:14 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Like any engine combo it all depends on your goals for it. A 451-499 with a 6.760 rod is a stout street-strip engine with a STD port head. My opinion on the 496-512 is the shorter rod requires a max wedge or B1 size intake port. Also 1.6-1.7 rockers and an aggressive intake lobe. Without getting into to much the piston in these combos moves away from TDC FAST and it needs plenty of flow volume available when it does. STD port heads and a larger than needed cam grind can crutch this but the engine will not reach is power potential without enough port AND intake volume. Some calculations on Larry Meax's software is eye opening.
Re: Best stroker kit for a 383/440? [Re: RUMBLON] #3139235
04/19/23 11:04 AM
04/19/23 11:04 AM
AndyF Offline
AndyF  Offline
For a street car I'd go with the 4.25 inch stroke crankshaft regardless of the block. The 400 is probably the best block to use followed by the 440 and then the 383. Any will work, but the 400 gives you a very nice combination of power and size. The 440 block might make it a little easier to find headers and intakes and stuff like that so if you have a good 440 block I'd use it.
500 inches with the 4.25 crank and a set of good aluminum heads will give you plenty of street power, even with a smallish street friendly cam. We build these engines all the time and depending on which heads and cam you pick you can see up to 600 ft-lbs of torque and between 500 to 600 hp.
Re: Best stroker kit for a 383/440? [Re: JERICOGTX] #3139238
04/19/23 11:07 AM
04/19/23 11:07 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I would highly recommend Molnar crank and rods. Mahle pistons are also really nice. We've had ours since 2016 and they have been awesome! 4.25 stroke, 2.20 rods and 7.1" long rods (440 RB).
I like to think I torture test stuff more thoroughly than most people grin what with all the hard street miles and drag strip passes we make with a big, heavy car and lots of spray.
'63 Dodge 330
11.19 @ 121 mph
Re: Best stroker kit for a 383/440? [Re: GY3] #3139267
04/19/23 12:22 PM
04/19/23 12:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I wouldn't say 440 Source's quality has gone down.
2011 Drag Pak Challenger
Re: Best stroker kit for a 383/440? [Re: rickseeman] #3139288
04/19/23 01:32 PM
04/19/23 01:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I agree with this ^^^^^^^^^
Re: Best stroker kit for a 383/440? [Re: CSK] #3139296
04/19/23 02:29 PM
04/19/23 02:29 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
I'm surprised nobody has offered two cents regarding doing a G3. I built a very mild 400 based 512 stroked motor back in 2018 and have been very pleased with it. I would probably give a 6.4 G3 a lot more thought now. Cast parts and O-ring gaskets. Everything just seems to seal up so much better than the old stuff.
Re: Best stroker kit for a 383/440? [Re: rickseeman] #3139297
04/19/23 02:50 PM
04/19/23 02:50 PM
Dragula Offline
Dragula  Offline
Pretty much all we build when it comes to strokers......My goal though is to switch to a G3 with some kind of pressure adder in my one car.
Re: Best stroker kit for a 383/440? [Re: RUMBLON] #3139306
04/19/23 03:48 PM
04/19/23 03:48 PM
AndyF Offline
AndyF  Offline
Here is a low deck 512 that we ran at the end of last year. Pump gas compression, mild cam, Trick Flow 240 heads. Made 600 ft-lbs of torque and 550 hp. Very simple build, most of the parts come from Summit. No trick machine work, just do the basics and double check everything. Goes right together without any issues.
Re: Best stroker kit for a 383/440? [Re: AndyF] #3139317
04/19/23 04:54 PM
04/19/23 04:54 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What were the cam specs on that one?
Re: Best stroker kit for a 383/440? [Re: RUMBLON] #3139326
04/19/23 06:25 PM
04/19/23 06:25 PM
Utah, USA
1964superstock Offline
Utah, USA
Who sells the best stroker kit with highest quality needed parts, crank, rods, pistons, rings, bearings, such as Molnar crank and rods, Mahle pistons?
Best to just buy individual parts and piece it all together?
Re: Best stroker kit for a 383/440? [Re: mopowers] #3139354
04/19/23 08:05 PM
04/19/23 08:05 PM
AndyF Offline
AndyF  Offline
I think it was 236/244 but I'm not 100% sure anymore. It wasn't the "perfect" cam for the engine, but cores were hard to find so the customer bought a cam that he found on the shelf. It worked pretty good for what it was.
Re: Best stroker kit for a 383/440? [Re: 1964superstock] #3139355
04/19/23 08:07 PM
04/19/23 08:07 PM
AndyF Offline
AndyF  Offline
Depends on what you're trying to do. If you are going to build a serious race engine then I'd buy the best parts you can and piece them together. For a street engine one of the kits is the best deal providing that you can find one that gives you the correct compression ratio with the heads you are going to run.
Re: Best stroker kit for a 383/440? [Re: rickseeman] #3139360
04/19/23 08:26 PM
04/19/23 08:26 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I wouldn't say they were up there with the top quality stuff either. You get what you pay for & I wouldn't go cheap on the spinning stuff.
Re: Best stroker kit for a 383/440? [Re: AndyF] #3139501
04/20/23 12:50 PM
04/20/23 12:50 PM
Utah, USA
Utah, USA
Thanks Andy F for the info. What suppliers do you recommend checking out for a 4.25 inch stroke kit for 440 for a fun fast street car? What brand crank, rods, pistons, rings, bearings do you use?
