torsion bar question #313926
05/10/09 03:29 PM
05/10/09 03:29 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
Hi, can torsion bars fatique?, I know they break, but can they lose thier strength, when I adjust the front end, the adjustment screw on the lower bar goes in further than the passenger-side in order to make the front end even. I appreciate your opinions...thanks
Semper Fi
Re: torsion bar question [Re: GOLDMYN] #313927
05/10/09 03:33 PM
05/10/09 03:33 PM
Kirkland, Washington
Pacnorthcuda Offline
Uneven positioning of the adjuster bolt (in order to reach an even ride height) is more common than not. If you think about all the variables affecting one side vs the other (not just the bars)it makes sense. Unless one bolt is all the way in and the other all the way out (which might indicate a bar that is miss-clocked) I would not worry about it.
Re: torsion bar question [Re: GOLDMYN] #313928
05/10/09 03:53 PM
05/10/09 03:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Also, if the lower bushings are worn different, the bars get loaded a hair different to get the car level. But a bushing would usually need to be worn almost through the rubber. (Not good) I saw a couple like that where the inner and outer lower bushing shells were already wearing through each other.
Re: torsion bar question [Re: buildanother] #313929
05/10/09 04:28 PM
05/10/09 04:28 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
I just had the complete front-end rebuilt, will the bar fatique?
Semper Fi
Re: torsion bar question [Re: GOLDMYN] #313930
05/10/09 08:30 PM
05/10/09 08:30 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Yes. Just like coil and leaf springs fatigue.
Re: torsion bar question [Re: GOLDMYN] #313931
05/10/09 10:35 PM
05/10/09 10:35 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
sounds like the complete front end was not rebuilt of they are old bars
Re: torsion bar question [Re: GOLDMYN] #313932
05/10/09 10:42 PM
05/10/09 10:42 PM
How much further in
Re: torsion bar question [Re: RapidRobert] #313933
05/10/09 11:02 PM
05/10/09 11:02 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
yes, rebuilt except the old bars and the screw goes in perhaps 3/8 further on the driver-side
Semper Fi
Re: torsion bar question [Re: GOLDMYN] #313934
05/10/09 11:17 PM
05/10/09 11:17 PM
Your in good shape
Re: torsion bar question [Re: RapidRobert] #313935
05/12/09 02:15 PM
05/12/09 02:15 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've never see any Mopar with same thread count showing on the adjusters, new or old suspension.
