How to choose a flywheel
#3139025
04/18/23 03:12 PM
04/18/23 03:12 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
Doing a 69 rr. The engine is a stock 67 440. All 4 of my options are slightly different. Is there something to look for to balance right for that engine? I'll try and post a pic.
68 Satellite Wagon and a few other ones
Re: How to choose a flywheel
[Re: mro]
#3139028
04/18/23 03:17 PM
04/18/23 03:17 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
How I choose one is to go to Summit and buy a NEW BILLET wheel , my feet are worth more than the savings of using an OLD, heat checked, cracked cast steel flywheel, especially if you aren't running a blowsheild.
[Re: JohnRR]
#3139140
04/18/23 10:35 PM
04/18/23 10:35 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
How I choose one is to go to Summit and buy a NEW BILLET wheel , my feet are worth more than the savings of use an OLD heat checked cracked cast steel flywheel, especially if you aren't running a blowsheild. I agree. By the time you pay a machine shop to resurface your old one, you aren't that far away from a good steel replacement. Your old stock one might be just fine until one day in the heat of the moment, you decide to race someone and dump the clutch at higher revs. Then it's off to the rehab hospital for some new feet. Personally I won't run anything but a stock engine without a scattershield. -Charles
[Re: mro]
#3139274
04/19/23 12:54 PM
04/19/23 12:54 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The flywheel with the casting number 2843212 is a 143-tooth and no engines that used that flywheel were externally balanced...last used in '69.
[Re: dragon slayer]
#3140195
04/23/23 04:07 PM
04/23/23 04:07 PM
John_Kunkel
Rio Linda, CA
'62-later Mopar flywheels:
172 tooth= 14.75" if you measure across the ring gear.
143 tooth= 14.568" at the ring gear
130 tooth= 13.195" at the ring gear
[Re: dragon slayer]
#3140253
04/23/23 09:38 PM
04/23/23 09:38 PM
Posts: 43,241 Bend,OR USA
Cab_Burge
[quote=dragon slayer][quote=Cab_Burge]T I don't think mopar used a 140 tooth flywheel.] You are CORRECT My mistake hurrying to type Corrected now
