69 rr dash krinkle paint
#3138931
04/18/23 08:48 AM
04/18/23 08:48 AM
Posts: 1,107 Lynch Road
mro
Lynch Road
Can I still get this mixed ? Green. Thx
68 Satellite Wagon and a few other ones
Re: 69 rr dash krinkle paint
[Re: mro]
#3138933
04/18/23 09:00 AM
04/18/23 09:00 AM
Posts: 1,385 Az
69hemibeep
Az
Call these people and ask for the restoration shop. Tell them you are after suede paint and what color. Aint cheap but it is the correct stuff. https://tcpglobal.com/pages/restoration-shop
1969 Hemi Roadrunner 2nd owner
[Re: Stanton]
#3139123
04/18/23 09:44 PM
04/18/23 09:44 PM
Posts: 1,755 Phila
PhillyRag
Phila
If you can find a paint supplier that still sells lacquer then they can mix it from the code in the FSM. Last I checked: not the paint that'a the problem, but the Suede additive used. Anyone know what component was added to give that finish? Had used a PPG black textured lacquer 1 time. Suede was like a very fine sandy particle was added to the paint..
[Re: PhillyRag]
#3139128
04/18/23 10:05 PM
04/18/23 10:05 PM
Posts: 8,874 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Anyone know what component was added to give that finish? As a matter of fact I do ... and its sold on Amazon. However, finding or buying it isn't the problem. First you need to know which shade to use - flat, satin, semi gloss, etc. THEN you need to know how much of the additive to use. I'll find the stuff and post here shortly. Well I just did a search and now I can't find it. Give me a day or so - I'm probably not using the same search words I did last time.
[Re: TJP]
#3139211
04/19/23 08:59 AM
04/19/23 08:59 AM
Posts: 1,385 Az
69hemibeep
Az
What's not cheap? I have a 1/2 pint or so of non thinned black suede left over form my Charger that I did years ago. If I remember correctly that would = a quart mixed which should be more than enough to do a dash and column. Doubt I'll ever have a need for it I don't remember if I ordered a pint or quart but it was $215 some years ago but it covered 2 dashes and 1 steering column in black
[Re: 69hemibeep]
#3139307
04/19/23 03:51 PM
04/19/23 03:51 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Photos of the TCP Global suede dash paint in 69 Black & 69 Tan on recent dashes I restored. Very nice...I highly recommend them.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: topside]
#3140333
04/24/23 10:36 AM
04/24/23 10:36 AM
70gtx440dana
Lansing, MI
^^^ That looks legit, especially the one on the right (likely because of less camera flash).
The dash pads are intriguing - seem to differ from each other; I'm not bustin' your stones, just curious... Dash pads are the same....tan one had to be dyed as it was made in black vinyl. The black one is as made....no dye.
[Re: 70gtx440dana]
#3140364
04/24/23 12:17 PM
04/24/23 12:17 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Photos of the TCP Global suede dash paint in 69 Black & 69 Tan on recent dashes I restored. Very nice...I highly recommend them. Beautiful. That is exactly what I need. Thanks
Rich H.
Esse Quam Videri
