Re: 1998 46RE Band Adjustment
[Re: 1969ronnie]
#3140887
04/26/23 04:59 PM
04/26/23 04:59 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Pretty sure that's what the trans should do , it's easy to turn one way and has a drag in the other because the rear drum is being grabbed by the rear sprag and it's turning thru a planetary gearset I believe. ?? That trans originally had ATF+3 but now switched ... as much as I hate to say ...+4.
[Re: 1969ronnie]
#3141001
04/27/23 11:52 AM
04/27/23 11:52 AM
Posts: 25,961 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Thanks for Help Guys . I knew I had a problem with My Bands on this Customers Vehicle when Driveshaft would Turn OK in 1 Direction , But DRAG going the other direction with NO tire rims , or brake drums. When viewed from the rear looking forward, normal rotation is counterclockwise, turning in the opposite direction will take much more force...perfectly normal. That's why a car is harder to push backward.
