1998 46RE Band Adjustment #3137396
04/12/23 02:48 PM
04/12/23 02:48 PM
massachusetts U.S.A.
1969ronnie Offline OP
wave Hi , I can't find the 2 Band Adjustment Turns in Moparts library . Any Member know for sure , or could post them . Some Info says 2 7/8 or 2 on front Band , and 2 Turns or 3 on Reverse Band Thank You in advance . drive Ronnie
Re: 1998 46RE Band Adjustment [Re: 1969ronnie] #3137421
04/12/23 03:37 PM
04/12/23 03:37 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
From the 2001 service manual:
ADJUSTMENT - BANDS
FRONT BAND
The front (kickdown) band adjusting screw is
located on the left side of the transmission case
above the manual valve and throttle valve levers.
(1) Raise vehicle.
(2) Loosen band adjusting screw locknut (Fig. 73).
Then back locknut off 3-5 turns. Be sure adjusting
screw turns freely in case. Apply lubricant to screw
threads if necessary.
(3) Tighten band adjusting screw to 8 N·m (72 in.
lbs.) torque with Inch Pound Torque Wrench
C-3380-A, a 3-in. extension and an appropriate
Torx™ socket.
CAUTION: If Adapter C-3705 is needed to reach the
adjusting screw, tighten the screw to only 5 N·m
(47-50 in. lbs.) torque.
(4) Back off front band adjusting screw 2-7/8
turns.
(5) Hold adjuster screw in position and tighten
locknut to 41 N·m (30 ft. lbs.) torque.
(6) Lower vehicle.
REAR BAND
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns.
Be sure adjusting screw turns freely in lever.
(4) Tighten adjusting screw to 8 N·m (72 in. lbs.)
torque (Fig. 74).
(5) Back off adjusting screw 2 turns.
(6) Hold adjusting screw in place and tighten locknut to 34 N·m (25 ft. lbs.) torque.
(7) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 17 N·m (13 ft.
lbs.) torque.
(8) Lower vehicle and refill transmission with
Mopart ATF +4, Type 9602 fluid.
Re: 1998 46RE Band Adjustment [Re: 1969ronnie] #3137951
04/14/23 12:34 PM
04/14/23 12:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I tighten it so I can pass a 5/16 allen wrench between the apply lever and the servo tip
Re: 1998 46RE Band Adjustment [Re: JohnRR] #3138500
04/16/23 04:20 PM
04/16/23 04:20 PM
moparx Offline
moparx  Offline
i saw that somewhere as well, John.
it may have been in the ATSG books, or a TransGo kit instructions, i forget.
beer
Re: 1998 46RE Band Adjustment [Re: moparx] #3140874
04/26/23 03:57 PM
04/26/23 03:57 PM
wave Thanks for Help Guys . I knew I had a problem with My Bands on this Customers Vehicle when Driveshaft would Turn OK in 1 Direction , But DRAG going the other direction with NO tire rims , or brake drums. The Low Reverse internal Band was on the Loose side at just over 3 Turns . The outside Kickdown Band was 1 3/4 , mabe 2 turns if I cranked on Band Bolt , Way too Tight , But easy for the Quicky Lube Guys to Tighten the Crap out of the Band Adjustment screw . I also turned pressure Adjustment 1/2 a turn to get 9/32" between the retainer and line pressure adjusting plate nut . Driveshaft now turns the same slight drag in both Directions . NO Massive Parasitic DRAG anymore . drive Just need to fill this 1998 with what ATF ? runaway argue shout
Re: 1998 46RE Band Adjustment [Re: 1969ronnie] #3140887
04/26/23 04:59 PM
04/26/23 04:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty sure that's what the trans should do , it's easy to turn one way and has a drag in the other because the rear drum is being grabbed by the rear sprag and it's turning thru a planetary gearset I believe. ??
That trans originally had ATF+3 but now switched ... as much as I hate to say ...+4.
Re: 1998 46RE Band Adjustment [Re: 1969ronnie] #3141001
04/27/23 11:52 AM
04/27/23 11:52 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When viewed from the rear looking forward, normal rotation is counterclockwise, turning in the opposite direction will take much more force...perfectly normal. That's why a car is harder to push backward.
Re: 1998 46RE Band Adjustment [Re: John_Kunkel] #3141031
04/27/23 02:44 PM
04/27/23 02:44 PM
wave Hi John's , Yes I Agree Driveshaft should have some Drag in 1 direction . But this Drag was Excessive . The front Band was SO tight from Jiffy Lube Guys , that by having Driveshaft Disconnected at Rear Yoke , only turning Band Bolt 1/2 turn tighter LOCKED DRIVESHAFT SOLID . Backed it off 1 Turn , Nice and Normal drag .. When I first checked this Vehicle , I was Convinced it had Frozen Stuck applied E Brake cables . Thanks Guys . Now to fill with ATF+4 . drive
