Light weight hood springs #3137231
04/11/23 07:50 PM
04/11/23 07:50 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Looking for a set of hood springs similar to the 1970 T/A-AAR. Just put a glass hood on the GF's GTX and she insist it stay open on it's own (no prop rod). Any one have a source for these? Thanks!
Re: Light weight hood springs [Re: mercman1] #3137237
04/11/23 08:01 PM
04/11/23 08:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
try gate springs from the hardware store
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Light weight hood springs [Re: tex013] #3137240
04/11/23 08:31 PM
04/11/23 08:31 PM
BDW Online content
BDW  Online Content
Do B-bodies have holes in the hinges like E-bodies.
This is a simple solution that works great, bend up some 1/4" rod
Re: Light weight hood springs [Re: BDW] #3137280
04/11/23 11:18 PM
04/11/23 11:18 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
VFN sold me a pair when I bought the hood from them for my 67, they work great, they had a couple of different rate springs, any fiberglass shop that sells hoods should sell them.
Re: Light weight hood springs [Re: old_racer] #3137288
04/11/23 11:50 PM
04/11/23 11:50 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Atomic Dog sells them here and on other sites. I have a set and they work great.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Light weight hood springs [Re: BloFish] #3137333
04/12/23 10:50 AM
04/12/23 10:50 AM
an8sec70cuda Offline
Mine came from Glasstek.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Light weight hood springs [Re: an8sec70cuda] #3137350
04/12/23 12:24 PM
04/12/23 12:24 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have Harwood 210 part # gold medium tension springs on my car. I have a bolt on fiberglass custom made shaker hood by me, but it is not a race weight extra light hood. They also have a 200 part # that is a low tension silver spring and also a 215 part # that is a high tension black spring. I would try the 210 gold springs for your hood also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Light weight hood springs [Re: 6PKRTSE] #3137444
04/12/23 04:26 PM
04/12/23 04:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This:
Re: Light weight hood springs [Re: Stanton] #3137446
04/12/23 04:27 PM
04/12/23 04:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What I've noticed is that the spring serves two purposes - it not only holds the hood open but also pulls it down tight when closed.
Re: Light weight hood springs [Re: old_racer] #3137550
04/12/23 11:14 PM
04/12/23 11:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What was the # weight of springs, I plan on using a glass hood with the RO scoop on my 66
Re: Light weight hood springs [Re: cudaman1969] #3138739
04/17/23 01:36 PM
04/17/23 01:36 PM
moparx Offline
moparx  Offline
if i remember from Mr. P-Body [R.I.P. my friend. your vast knowledge and contributions to this site will be sadly missed ! angel] K-car hood springs were the same design as the A-body springs, which are a spiral wound type of spring hiding under the fender attaching to the hinge, rather than the common B-body exposed spring, and were a lighter tension.
beer
Re: Light weight hood springs [Re: moparx] #3138989
04/18/23 12:37 PM
04/18/23 12:37 PM
Locomotion Offline
Locomotion  Offline
I got some from a Dodge Daytona/Shadow, etc. to replace a broken original for my Dart Lite (steel/aluminum hood) but with added scoop. (They weigh about 15 lbs less than all-steel.Dart hood They were a little weaker and didn't consistently keep it up so I used a prop stick with it. I hadn't tried it without the hood scoop. They would probably work good with a heavy fiberglass hood. OEM springs for all steel hoods are just too much will bend the hood in the middle.
Re: Light weight hood springs [Re: 6PKRTSE] #3154230
06/25/23 08:24 PM
06/25/23 08:24 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
6PKRTSE, you hit the nail on the head! I ordered the Harwood 210 off Amazon (Cheapest price. Under $80 bucks) and they work perfect!
Little installation tip: overall length of the spring when the hood is up should be about 11.5 inches. I used a come along to stretch the spring to that length and put wrenches between EACH coil. put the spring in place and remove one wrench at a time, Repeat process for the other spring.
The Queen is now happy with her new hood.
