Re: Road Runner updates
[Re: Gabby63]
#3137217
04/11/23 05:49 PM
04/11/23 05:49 PM
Posts: 10,022 MN
JERICOGTX
MN
Man that is a sweet car , detail is awesome . Just asking if you have a better photo of throttle cable mount at carb ? I am trying to fab a new one for my B-body . Stock cable seems too short for my mount & will not open completely with dominator . Thanks for posting your car , Gary Here you go.
69 GTX
68 Road Runner
[Re: RobR]
#3137239
04/11/23 08:25 PM
04/11/23 08:25 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
That is one very well engineered stick car. Got any pics of the clutch linkage ? Is it still off the firewall or is it a pivot style on the floor like a Bickel pro-stock deal? Thanks for sharing your build. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3137241
04/11/23 08:40 PM
04/11/23 08:40 PM
Posts: 10,022 MN
JERICOGTX
MN
Gus, the clutch linkage is stock, except it uses hiem joints.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3137244
04/11/23 09:01 PM
04/11/23 09:01 PM
fourgearsavoy
Rittman Ohio
Yeah it makes all the difference in the world when you can remove all the play in the clutch and shifter links with heim joints. Gus
[Re: dvw]
#3137305
04/12/23 08:17 AM
04/12/23 08:17 AM
Posts: 10,022 MN
JERICOGTX
MN
Can't wait to see video. Doug I'll post it when I get it!
69 GTX
68 Road Runner
[Re: fourgearsavoy]
#3137308
04/12/23 08:18 AM
04/12/23 08:18 AM
Posts: 10,022 MN
JERICOGTX
MN
Yeah it makes all the difference in the world when you can remove all the play in the clutch and shifter links with heim joints. Gus It's really the only way to get consistency out of the clutch.
69 GTX
68 Road Runner
[Re: Bad340fish]
#3137326
04/12/23 10:10 AM
04/12/23 10:10 AM
Posts: 17,845 S.E. Michigan
ZIPPY
S.E. Michigan
It still has room for groceries!
This car raises the bar WAY up there on quality and detail, but the best part is the builder remains very humble about his capabilities and is very quick to give others credit for the Hundreds of great ideas displayed.
Rich H.
Esse Quam Videri
[Re: JERICOGTX]
#3137468
04/12/23 06:17 PM
04/12/23 06:17 PM
Posts: 343 Indiana
Gabby63
Indiana
Thank you , did you fab this plate ? If so any close pics of that ? Thanks again Gary
Are you using a stock pedal assembly inside of car ?
[Re: Gabby63]
#3137499
04/12/23 08:05 PM
04/12/23 08:05 PM
Posts: 10,022 MN
JERICOGTX
MN
I am using a stock pedal assembly. The throttle bracket was made by a friend of mine. I drew it up, and made it out of thin plywood first. It acts as a safety plate for a Dominator, holds the fuel regulator, and throttle cable, all in one.
69 GTX
68 Road Runner
[Re: moparx]
#3138751
04/17/23 02:05 PM
04/17/23 02:05 PM
Posts: 10,022 MN
JERICOGTX
MN
what [stainless ?] bolts are you using on your engine, and what manufacturer are they ? i intend to paint the replacement 446 for my charger the same color turquoise, and use bolts like you are using. Almost every bolt on the engine is from ARP. I just measure what I need and order accordingly. It sucks when you need 6 bolts, and they come in packs of 5, but that is what it takes sometimes.
69 GTX
68 Road Runner
