Page 3 of 5 1 2 3 4 5
Re: Road Runner updates [Re: JERICOGTX] #3137213
04/11/23 05:07 PM
04/11/23 05:07 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Man that is a sweet car , detail is awesome . Just asking if you have a better photo of throttle cable mount at carb ? I am trying to fab a new one for my B-body . Stock cable seems too short for my mount & will not open completely with dominator . Thanks for posting your car , Gary
Re: Road Runner updates [Re: Gabby63] #3137217
04/11/23 05:49 PM
04/11/23 05:49 PM
MN
JERICOGTX Offline OP
MN
Here you go.
69 GTX 68 Road Runner
Re: Road Runner updates [Re: JERICOGTX] #3137219
04/11/23 06:00 PM
04/11/23 06:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A tip of my hat to you for the details & the thought put into the car.
I dare say you'll be putting the wheelie bars to frequent use.
I always ran the ones on my Duster at 10" for fun, and it's always been a popular move...
Re: Road Runner updates [Re: topside] #3137224
04/11/23 06:34 PM
04/11/23 06:34 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Wow that is one amazing build. Good for you. Can’t wait to hear how it does.
Re: Road Runner updates [Re: 71Demon528] #3137229
04/11/23 07:34 PM
04/11/23 07:34 PM
tboomer Offline
tboomer  Offline
Good luck Jeff! up
Re: Road Runner updates [Re: tboomer] #3137230
04/11/23 07:45 PM
04/11/23 07:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Can't wait to see video.
Doug
Re: Road Runner updates [Re: dvw] #3137235
04/11/23 07:53 PM
04/11/23 07:53 PM
Canada
RobR Offline
RobR  Offline
Canada
Very Nice ! up
Re: Road Runner updates [Re: RobR] #3137239
04/11/23 08:25 PM
04/11/23 08:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That is one very well engineered stick car. Got any pics of the clutch linkage ? Is it still off the firewall or is it a pivot style on the floor like a Bickel pro-stock deal?
Thanks for sharing your build. up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Road Runner updates [Re: fourgearsavoy] #3137241
04/11/23 08:40 PM
04/11/23 08:40 PM
MN
MN
Gus, the clutch linkage is stock, except it uses hiem joints.
Re: Road Runner updates [Re: JERICOGTX] #3137244
04/11/23 09:01 PM
04/11/23 09:01 PM
Rittman Ohio
Rittman Ohio
Yeah it makes all the difference in the world when you can remove all the play in the clutch and shifter links with heim joints.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Road Runner updates [Re: dvw] #3137305
04/12/23 08:17 AM
04/12/23 08:17 AM
MN
MN
Doug
I'll post it when I get it!
Re: Road Runner updates [Re: fourgearsavoy] #3137308
04/12/23 08:18 AM
04/12/23 08:18 AM
MN
MN
Gus beer
It's really the only way to get consistency out of the clutch.
Re: Road Runner updates [Re: JERICOGTX] #3137324
04/12/23 09:56 AM
04/12/23 09:56 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Beautiful, just needs license and registration for the street grin
68 Barracuda Formula S 340
Re: Road Runner updates [Re: Bad340fish] #3137326
04/12/23 10:10 AM
04/12/23 10:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It still has room for groceries!
This car raises the bar WAY up there on quality and detail, but the best part is the builder remains
very humble about his capabilities and is very quick to give others credit for the
Hundreds of great ideas displayed.
Rich H.
Esse Quam Videri
Re: Road Runner updates [Re: JERICOGTX] #3137468
04/12/23 06:17 PM
04/12/23 06:17 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Thank you , did you fab this plate ? If so any close pics of that ? Thanks again Gary
Are you using a stock pedal assembly inside of car ?
Re: Road Runner updates [Re: Gabby63] #3137499
04/12/23 08:05 PM
04/12/23 08:05 PM
MN
MN
I am using a stock pedal assembly. The throttle bracket was made by a friend of mine. I drew it up, and made it out of thin plywood first. It acts as a safety plate for a Dominator, holds the fuel regulator, and throttle cable, all in one.
Re: Road Runner updates [Re: JERICOGTX] #3137801
04/13/23 07:09 PM
04/13/23 07:09 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Thank you for the info . I made a stainless bracket which bolts to carb base studs , Not in favor of using the carb mounting bolts for this but no choice yet . I modified the interior pedal to try to account for more throw , so far I am very close to the stop on carb being all the way open . May have to explore a better inside pedal . The Locar pedal I have is very chinzy at best , so I went back to stock pedal . Gary
Re: Road Runner updates [Re: Gabby63] #3138746
04/17/23 01:49 PM
04/17/23 01:49 PM
moparx Offline
moparx  Offline
what [stainless ?] bolts are you using on your engine, and what manufacturer are they ?
i intend to paint the replacement 446 for my charger the same color turquoise, and use bolts like you are using. up bow
beer
Re: Road Runner updates [Re: moparx] #3138751
04/17/23 02:05 PM
04/17/23 02:05 PM
MN
MN
beer
Almost every bolt on the engine is from ARP. I just measure what I need and order accordingly. It sucks when you need 6 bolts, and they come in packs of 5, but that is what it takes sometimes.
Re: Road Runner updates [Re: JERICOGTX] #3138769
04/17/23 03:15 PM
04/17/23 03:15 PM
moparx Offline
moparx  Offline
thank you. up
i thought ARP, as they have the stainless bolts that are not the elcheapistan packages you see at swap meets made of chinesium.
theirs [ARP's] are made of good quality stainless of a good strength/grade for the particular application.
beer
