See Ya ! #3137023
04/10/23 08:13 PM
04/10/23 08:13 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Seriously, thanks to all that contributed. The picture shows the culprit. Damn, what a head scratcher. On a rotisserie they took short cuts on $30 wires?
Re: See Ya ! [Re: Kudakidd] #3137027
04/10/23 08:26 PM
04/10/23 08:26 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Looks like they just put together a set from a bunch of used ones they had laying around.
I like Firecore wires for anything from a street car to a top fueler.
Gus beer
64 Plymouth Savoy
Dana 60
Re: See Ya ! [Re: fourgearsavoy] #3137029
04/10/23 08:35 PM
04/10/23 08:35 PM
Guitar Jones Offline
Gus beer
Damn, when did you get a top fuel car? Spill the beans man!
Re: See Ya ! [Re: Kudakidd] #3137049
04/10/23 09:54 PM
04/10/23 09:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Seen it more than once,
We used to refer to is as "The customers out of money" (bi---ing) and we're out of time, finish it up and get it outta here"
that should have been petty easy to spot pity
Re: See Ya ! [Re: TJP] #3137121
04/11/23 09:54 AM
04/11/23 09:54 AM
Kudakidd Offline OP
Kudakidd  Offline OP
All of the wires were black and the distributor cap boots were all the same. It wasn't until I pulled the spark plugs that I found the problem. Plus the miss was a high speed problem only. The engine idled and ran fine until about 4k rpm.
Re: See Ya ! [Re: Kudakidd] #3137174
04/11/23 01:59 PM
04/11/23 01:59 PM
central il.
second 70 Offline
second 70  Offline
central il.
I'm glad you were able to find the problem. I'm 99% sure that the previous owner got disgusted with the car not running right and there's a good chance that's the only reason he sold it.
Re: See Ya ! [Re: second 70] #3137234
04/11/23 07:53 PM
04/11/23 07:53 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Originally Posted by second 70
[quote=Kudakidd]
I like your way of thinking.
Re: See Ya ! [Re: Guitar Jones] #3137238
04/11/23 08:10 PM
04/11/23 08:10 PM
Rittman Ohio
Rittman Ohio
Gus beer
Nah I just know a top fuel driver that runs Rick's wires on his dragster.
Gus beer
64 Plymouth Savoy
Dana 60
Re: See Ya ! [Re: Kudakidd] #3137301
04/12/23 07:59 AM
04/12/23 07:59 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I like the old Magnecor wires I have,
and have tested using a Biddle Megger, salt water, or after a suggestion here on Moparts,
strips of aluminum foil wrapped around the wires to test for shorts.
I liked the technical information that the “old” Magnecor put on their website, but is unfortunately now gone, but is on the Internet Archive Wayback machine.
I like how the grade of insulation used on the old Magnecor wires has held up since 1998.
I like how Magnecor offers the option of buying special wires that reduce radio Frequency Interference (RFI)
I like how Magnecor put on their website the Dodge Ram TSB about cross fire using the original factory wire routing.
https://magnecorusa.com/v8/
I am not totally confident the new owners of Magnecor will provide the customer service of the original owner, but they have expanded worldwide and offer lots more options.
Re: See Ya ! [Re: Kudakidd] #3137539
04/12/23 10:39 PM
04/12/23 10:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
[quote=Kudakidd]
I've had MANY through the shop that were likely sold for the reason mentioned. i could write a book on the issues we've straightened out. wink
Re: See Ya ! [Re: Kudakidd] #3137690
04/13/23 11:36 AM
04/13/23 11:36 AM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=Kudakidd]
Been a long time since someone told me that. LOL
