I'll try and remember tomorrow to take a picture of mine (1966 Dodge Deluxe 2 dr. sedan), it has a 1968 V8 K member in it due it being a original six cylinder three on the tree car that I put a 440 motor and a NP833 O.D. and a cut down Dana 60 truck rear end converted for street cruising.
That motor,440 small stroker, has Eddy RPM intake and a Holley D.P. carb on it, I think.
That air cleaner has a three inch drop base so I could use a taller air cleaner on that motor in that car
I hadn't noticed the air cleaner stud wing nut hitting the bottom of the hood making a tiny dent in it
