Stock 66 coronet carburetor question #3136571
04/08/23 07:26 PM
04/08/23 07:26 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Any pictures of a Holley carb on a stock 383 intake 66 coronet with no scoop? Having hood clearance issues. And fuel line issues. Thanks in advance
Re: Stock 66 coronet carburetor question [Re: bobs69] #3136578
04/08/23 07:53 PM
04/08/23 07:53 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi Bob , What Model # Holley ? Aftermarket or Original 1966 ? 2 BBL , or 4 BBL ? Series 4160 or a 4150 if 4 BBL ? We need more Info to Help You . drive Ronnie
Re: Stock 66 coronet carburetor question [Re: 1969ronnie] #3136580
04/08/23 07:58 PM
04/08/23 07:58 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
It’s a Holley 750 double pumper 4150
Re: Stock 66 coronet carburetor question [Re: bobs69] #3136600
04/08/23 09:55 PM
04/08/23 09:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I don't believe a 66 383 ever got a Holley carb from the factory. Certainly would not have been a double pumper Holley. The 66 383 was probably a Carter AFB or at most a Carter AVs.
A 66 383 had a very low rise intake, the highest point on those intakes was lower then the top of the valve covers. By 69, it was a different story, but those Coronet's had a higher hood line. Mopar didn't put any double pumper Holley's on any factory motors that I know of.
Re: Stock 66 coronet carburetor question [Re: poorboy] #3136615
04/08/23 10:52 PM
04/08/23 10:52 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I took a junky Edelbrock off and put the Holley on. Have hood clearance issues.
Re: Stock 66 coronet carburetor question [Re: bobs69] #3136616
04/08/23 10:55 PM
04/08/23 10:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
what doesn't clear? the top of the carb or the air cleaner stud?
Re: Stock 66 coronet carburetor question [Re: stumpy] #3136619
04/08/23 11:05 PM
04/08/23 11:05 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Without a spacer under the carb the lines won’t clear the intake. With the spacer the low profile air cleaner touches the hood. Maybe I’ll put a scoop on it.
Re: Stock 66 coronet carburetor question [Re: bobs69] #3136637
04/09/23 01:59 AM
04/09/23 01:59 AM
I'll try and remember tomorrow to take a picture of mine (1966 Dodge Deluxe 2 dr. sedan), it has a 1968 V8 K member in it due it being a original six cylinder three on the tree car that I put a 440 motor and a NP833 O.D. and a cut down Dana 60 truck rear end converted for street cruising.
That motor,440 small stroker, has Eddy RPM intake and a Holley D.P. carb on it, I think. confused That air cleaner has a three inch drop base so I could use a taller air cleaner on that motor in that car up
I hadn't noticed the air cleaner stud wing nut hitting the bottom of the hood making a tiny dent in it whiney
Re: Stock 66 coronet carburetor question [Re: Cab_Burge] #3136703
04/09/23 11:38 AM
04/09/23 11:38 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Seems to me the answer is to fab some fuel lines.
I've had a couple of early Bs with swapped-in RBs, Performer RPM intakes, and Holley 4150s, and no problems IF I used a drop-base air cleaner.
I didn't think the '66-'67 hood was lower than the '62-'64...
Re: Stock 66 coronet carburetor question [Re: topside] #3136817
04/09/23 08:29 PM
04/09/23 08:29 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Topside was correct I made my own. Problem solved. Thanks to everyone
Re: Stock 66 coronet carburetor question [Re: bobs69] #3136944
04/10/23 11:41 AM
04/10/23 11:41 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd recommend you get a GM heat insulator to prevent the gas in the bowls from boiling.
It's essentially an aluminum baffle, was used on Z28s.
