power window motor, 2018 challenger???? #3136559
04/08/23 06:16 PM
04/08/23 06:16 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I want to check the power window motor to make sure it works. It has 5 pins. One black wire, 4 orange wires with different stripes. I used a powermax jump box. Checked its output. 12.6 volts. I touched the negative off box to black pin, the positive off box to each of the 4 remaining pins. Nothing. This motor was good when taken off. Am I doing something wrong?
Thanks for any help, Kevin
Re: power window motor, 2018 challenger???? [Re: dart67] #3136584
04/08/23 08:14 PM
04/08/23 08:14 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I would expect these to have a few power inputs. The windows open slightly when the door handle is pulled and raise up fully when the doors are closed, plus their normal up and down function from the switch itself.
Is there a factory service manual for the car to access the wiring diagram?
Re: power window motor, 2018 challenger???? [Re: Kern Dog] #3136588
04/08/23 08:30 PM
04/08/23 08:30 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I'll check online.
Re: power window motor, 2018 challenger???? [Re: dart67] #3136658
04/09/23 09:04 AM
04/09/23 09:04 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You cant check them. The signal that runs the motor is sent thru CAN bus. We even tried to cheat them at FCA so we could put the windows up on partial builds that didn't have full wiring, nope.
Doug
Re: power window motor, 2018 challenger???? [Re: dvw] #3136664
04/09/23 09:22 AM
04/09/23 09:22 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Are you saying I cant run 12 volts to a set of pins in window motor to make it work?
Re: power window motor, 2018 challenger???? [Re: dart67] #3136709
04/09/23 12:01 PM
04/09/23 12:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sure what it sounds like.Isn't progress wonderful. grin
Re: power window motor, 2018 challenger???? [Re: stumpy] #3136779
04/09/23 06:19 PM
04/09/23 06:19 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Yeah,it's just great.....
Re: power window motor, 2018 challenger???? [Re: dart67] #3136781
04/09/23 06:22 PM
04/09/23 06:22 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I believe a man has got to have a degree in aerospace technology to work on this thing......
Re: power window motor, 2018 challenger???? [Re: dart67] #3136846
04/09/23 10:22 PM
04/09/23 10:22 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What exactly is the issue/problem with the power window?
That might help people help you to solve the problem.....
Re: power window motor, 2018 challenger???? [Re: dvw] #3136961
04/10/23 12:59 PM
04/10/23 12:59 PM
moparx Offline
moparx  Offline
Doug
i understand what you say, but a dc motor is/should be just a power and ground to work [eventually].
are these motors way different than what they were years ago ?
if you go directly to the motor, bypassing all the switches and wiring from the BCM CAN bus, can't it be jumped to work ?
what am i missing here ?
beer
Re: power window motor, 2018 challenger???? [Re: moparx] #3136999
04/10/23 05:45 PM
04/10/23 05:45 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i had this problem with S197 mustangs when working on them without a battery installed.
i had to connect the ground wire to the ground. the thick positive wire to the positive on jump box. and the thin wire that signals the window to roll down slightly when opening the door to positive also. the windows will roll down this way.
their are signal wires for both the L & R side doors. their are also signal wires to roll the window back up also. their is also a wire for memory on express up and down you don't have to worry about.
i would ASSuME the wiring is the same on a challenger.
perception is 90% of reality
Re: power window motor, 2018 challenger???? [Re: moparx] #3137098
04/11/23 06:50 AM
04/11/23 06:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
beer
You could take the motor apart to test the motor itself. It really wont tell you anything. As I stated there is a module in the motor that is controlled by CAN bus. Without the Can signal from the BCM (body controll module) it will not function. To make it worse the early and later Challenger's aren't the same. The drag cars get a cheater module that replicates the BCM commands. Also note that a Challenger window is commanded slightly down when the door handle/latch module (DDM) sends a signal to the BCM. It also commands the window slightly up when the door is shut. I worked in the Electrical garage at FCA Engineering debugging prototype build electrical issues. Didn't design them. Just had the joy of making them function.
Doug
Re: power window motor, 2018 challenger???? [Re: dvw] #3138525
04/16/23 05:45 PM
04/16/23 05:45 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Ain't progress wonderful?
It takes gasoline to interest me.
Re: power window motor, 2018 challenger???? [Re: VL21] #3138541
04/16/23 06:32 PM
04/16/23 06:32 PM
moparx Offline
moparx  Offline
HAHAHAHAHAHA !!!!!!!!!!!!!!!!!!! panic haha laugh2
beer
