Meth pumps #3133543
03/30/23 07:24 AM
03/30/23 07:24 AM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
What brand pumps are you all that run boosted application use.......Thanks coffee
Re: Meth pumps [Re: racerx] #3133589
03/30/23 11:00 AM
03/30/23 11:00 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I had a snow w/m kit for a while many yrs ago and I thing a high psi pump is out now.
Re: Meth pumps [Re: racerx] #3133628
03/30/23 12:52 PM
03/30/23 12:52 PM
I'm using a new Tanks Inc tank with their built in pump #GPA-8 which pumps 120 GPH at 100 PSI. This is on my 383 C.I on my 360 .LA motor with a turbo and a Holley Terminator X EFI direct port multi injection system running on pump E85.
I may need to add another pump for more volume at WOT to make sure it doesn't go lean and hurt the motor shruggy
I have called both Tanks Inc and Holley EFI on this build, both have been very helpful up
Re: Meth pumps [Re: Cab_Burge] #3133800
03/31/23 07:23 AM
03/31/23 07:23 AM
Mo.
Mo.
Cab....I think that pump you're referring to is a fuel pump shruggy I'm looking for an water /meth injection pump.
Re: Meth pumps [Re: Clanton] #3133801
03/31/23 07:28 AM
03/31/23 07:28 AM
Mo.
Mo.
Thanks Clanton up is Snow the name of the manufacture? If so I'll do a search.
Re: Meth pumps [Re: racerx] #3133805
03/31/23 08:01 AM
03/31/23 08:01 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
https://www.nitrousexpress.com/water-methanol-pumps/
Re: Meth pumps [Re: racerx] #3133877
03/31/23 12:13 PM
03/31/23 12:13 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There are a lot of places to get the pump other than snow and others mentioned with the same brand psi.
Re: Meth pumps [Re: blowndart] #3134090
04/01/23 06:11 AM
04/01/23 06:11 AM
Mo.
Mo.
Thank you Blowndart.....This is what i was looking for coffee
Re: Meth pumps [Re: racerx] #3135683
04/05/23 04:56 PM
04/05/23 04:56 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Initially I thought this thread was about some automated illicit drug device for addicts.
Floyd Lippencott IV
Re: Meth pumps [Re: mr_340] #3135941
04/06/23 01:10 PM
04/06/23 01:10 PM
moparx Offline
moparx  Offline
as a police commissioner in this great metropolis, that was my initial thought as well. laugh2
beer
Re: Meth pumps [Re: racerx] #3135958
04/06/23 02:30 PM
04/06/23 02:30 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
https://www.rbracing-rsr.com/waterinjection.html. I recommend anyone looking to do water/meth injection. Check these guys out or contact them. Been doing it a long time and know their stuff. Big time Bonneville guys who know how to run engines a long time at WOT
Re: Meth pumps [Re: HDNMOPERS] #3136050
04/06/23 09:31 PM
04/06/23 09:31 PM
Mo.
Mo.
Thank you I'll check them out up
Re: Meth pumps [Re: moparx] #3136051
04/06/23 09:32 PM
04/06/23 09:32 PM
Mo.
Mo.
beer
laugh2
