Re: Meth pumps
[Re: racerx]
#3133628
03/30/23 12:52 PM
03/30/23 12:52 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
I'm using a new Tanks Inc tank with their built in pump #GPA-8 which pumps 120 GPH at 100 PSI. This is on my 383 C.I on my 360 .LA motor with a turbo and a Holley Terminator X EFI direct port multi injection system running on pump E85. I may need to add another pump for more volume at WOT to make sure it doesn't go lean and hurt the motor I have called both Tanks Inc and Holley EFI on this build, both have been very helpful
Re: Meth pumps
[Re: Cab_Burge]
#3133800
03/31/23 07:23 AM
03/31/23 07:23 AM
Posts: 4,070 Mo.
racerx
Mo.
I'm using a new Tanks Inc tank with their built in pump #GPA-8 which pumps 120 GPH at 100 PSI. This is on my 383 C.I on my 360 .LA motor with a turbo and a Holley Terminator X EFI direct port multi injection system running on pump E85. I may need to add another pump for more volume at WOT to make sure it doesn't go lean and hurt the motor I have called both Tanks Inc and Holley EFI on this build, both have been very helpful Cab....I think that pump you're referring to is a fuel pump I'm looking for an water /meth injection pump.
Re: Meth pumps
[Re: Clanton]
#3133801
03/31/23 07:28 AM
03/31/23 07:28 AM
Posts: 4,070 Mo.
racerx
Mo.
I had a snow w/m kit for a while many yrs ago and I thing a high psi pump is out now. What brand pumps are you all that run boosted application use.......Thanks Thanks Clanton is Snow the name of the manufacture? If so I'll do a search.
Re: Meth pumps
[Re: racerx]
#3133877
03/31/23 12:13 PM
03/31/23 12:13 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
There are a lot of places to get the pump other than snow and others mentioned with the same brand psi. I had a snow w/m kit for a while many yrs ago and I thing a high psi pump is out now. What brand pumps are you all that run boosted application use.......Thanks Thanks Clanton is Snow the name of the manufacture? If so I'll do a search.
Re: Meth pumps
[Re: blowndart]
#3134090
04/01/23 06:11 AM
04/01/23 06:11 AM
Posts: 4,070 Mo.
racerx
Mo.
I had a snow w/m kit for a while many yrs ago and I thing a high psi pump is out now. What brand pumps are you all that run boosted application use.......Thanks Thanks Clanton is Snow the name of the manufacture? If so I'll do a search. https://www.nitrousexpress.com/water-methanol-pumps/ Thank you Blowndart.....This is what i was looking for
Re: Meth pumps
[Re: racerx]
#3135683
04/05/23 04:56 PM
04/05/23 04:56 PM
Posts: 3,505 DFW
mr_340
DFW
Initially I thought this thread was about some automated illicit drug device for addicts.
Floyd Lippencott IV
Re: Meth pumps
[Re: moparx]
#3136051
04/06/23 09:32 PM
04/06/23 09:32 PM
Posts: 4,070 Mo.
racerx
Mo.
