Newer Ram Truck fires? #3135594
04/05/23 01:07 PM
04/05/23 01:07 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
I have been looking for a 6.4 Hemi engine for a rebuildable core. Shopping salvage sites it seems there is a fair amount of these truck engines that have had engine fires. When shopping for a 6.4 from a car the burnt cores are far less. Just curious if there was an issue?
I don't know how to feel about buying a burnt engine core.
68 Barracuda Formula S 340
Re: Newer Ram Truck fires? [Re: Bad340fish] #3135616
04/05/23 01:58 PM
04/05/23 01:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Where did you hear the 6.4 was fire prone? Thats news to me. As far as a core it would be ok if it is cheap.
Re: Newer Ram Truck fires? [Re: NITROUSN] #3135688
04/05/23 05:03 PM
04/05/23 05:03 PM
Tulsa OK
Tulsa OK
I didn't hear there was a problem, I just noticed a lot of burned cores for truck motors vs the car motors.
Re: Newer Ram Truck fires? [Re: Bad340fish] #3135713
04/05/23 06:19 PM
04/05/23 06:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Years ago I saw the local yard had a Magnum core for $150 so went there to look at, it was a burned complete engine with the TB melted and all outside burnt. Got it home and found it to be very low mile excellent engine inside. Burned means injector lines burst and caught fire. These ARE the best finds.
Re: Newer Ram Truck fires? [Re: cudaman1969] #3135760
04/05/23 09:09 PM
04/05/23 09:09 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
2021–2023 Ram 2500 and 3500 pickups and chassis-cab trucks with the 6.7-liter Cummins diesel engine have a grid heater relay recall can catch fire running or not. And no fix at this time was told to leave outside garage in case it catches fire.........
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Newer Ram Truck fires? [Re: Bad340fish] #3136138
04/07/23 08:43 AM
04/07/23 08:43 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wonder if the 68RFE recall applies to the gas engine trucks too? Thought it was just the diesel.
Re: Newer Ram Truck fires? [Re: J_BODY] #3136235
04/07/23 01:58 PM
04/07/23 01:58 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Diesel only gas engines don't have grid heater relays.
Re: Newer Ram Truck fires? [Re: Savoy1964] #3136327
04/07/23 11:08 PM
04/07/23 11:08 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I was referring about the recall concerning the trans puking fluid out of the dipstick tube which can cause fire. Like I said I know there are diesel trucks involved, just not sure if the 6.4 trucks are too.
