Newer Ram Truck fires?
#3135594
04/05/23 01:07 PM
04/05/23 01:07 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have been looking for a 6.4 Hemi engine for a rebuildable core. Shopping salvage sites it seems there is a fair amount of these truck engines that have had engine fires. When shopping for a 6.4 from a car the burnt cores are far less. Just curious if there was an issue?
I don't know how to feel about buying a burnt engine core.
68 Barracuda Formula S 340
Re: Newer Ram Truck fires?
[Re: Bad340fish]
#3135616
04/05/23 01:58 PM
04/05/23 01:58 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I don't know how to feel about buying a burnt engine core. Where did you hear the 6.4 was fire prone? Thats news to me. As far as a core it would be ok if it is cheap.
[Re: NITROUSN]
#3135688
04/05/23 05:03 PM
04/05/23 05:03 PM
Bad340fish
Tulsa OK
I don't know how to feel about buying a burnt engine core. Where did you hear the 6.4 was fire prone? Thats news to me. As far as a core it would be ok if it is cheap. I didn't hear there was a problem, I just noticed a lot of burned cores for truck motors vs the car motors.
[Re: cudaman1969]
#3135760
04/05/23 09:09 PM
04/05/23 09:09 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
2021–2023 Ram 2500 and 3500 pickups and chassis-cab trucks with the 6.7-liter Cummins diesel engine have a grid heater relay recall can catch fire running or not. And no fix at this time was told to leave outside garage in case it catches fire.........
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: J_BODY]
#3136235
04/07/23 01:58 PM
04/07/23 01:58 PM
Savoy1964
Casco, MI
Diesel only gas engines don't have grid heater relays.
[Re: Savoy1964]
#3136327
04/07/23 11:08 PM
04/07/23 11:08 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
Diesel only gas engines don't have grid heater relays. I was referring about the recall concerning the trans puking fluid out of the dipstick tube which can cause fire. Like I said I know there are diesel trucks involved, just not sure if the 6.4 trucks are too.
