Re: Yeah, It's Me Again [Re: moparx] #3134461
04/02/23 02:23 PM
04/02/23 02:23 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
I'm in the camp of looking at the points. I had the identical symptoms to what you describe with my 440. It would idle and run under partial throttle just fine, and run terribly whenever you got on it. Turns out the points were worn so badly that I am amazed the car ran at all. Replaced the points and it runs great and performs like it should.
Re: Yeah, It's Me Again [Re: Kudakidd] #3134470
04/02/23 02:57 PM
04/02/23 02:57 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Question #1 Where is the Engine back firing? Carb or Exhaust? #2 What kind of distributor, points or electronic? #3 Where is your base timing set at idle? #4 which carb do you have?
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Yeah, It's Me Again [Re: Wicked49670dart] #3134565
04/02/23 07:46 PM
04/02/23 07:46 PM
Andrewh Offline
Andrewh  Offline
so additional questions.
does it do it in park?
if not does it matter from what rpm you start to get on it from?
and the questions above are important.
have you inspected the distributor points?
is it backfiring from the carb or exhaust?
Re: Yeah, It's Me Again [Re: Wicked49670dart] #3134572
04/02/23 08:14 PM
04/02/23 08:14 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
1 exhaust
2 points
3 factory setting
4 Holley 700 double pumper
Re: Yeah, It's Me Again [Re: Andrewh] #3134573
04/02/23 08:16 PM
04/02/23 08:16 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Not in neutral (it's a four speed)
points are new
backfiring from the exhaust
Re: Yeah, It's Me Again [Re: Kudakidd] #3134617
04/02/23 10:52 PM
04/02/23 10:52 PM
Did you or can you verify the TDC on the balancer and the timing cover to make sure what actual ignition timing you have now?
If not get some help to do that and then let us know what you found.
Also verify the firing order on the spark plugs wires and distributor cap are correct, 1843
6572 scope up twocents
Re: Yeah, It's Me Again [Re: Cab_Burge] #3134666
04/03/23 08:56 AM
04/03/23 08:56 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Back firing in the exhaust most of the time is a fuel/carb problem. Can you post a picture of a couple of the spark plugs? Few things to check, fuel pressure should be 5 to 7 psi, what is your base timing set to? Is this a new carb? Verify float levels at the bottom of sight on the bowls. do you have a different carb to try out? I would try to put 2 to 4 degree's more advance to see if any thing changes. Check engine vacuum at idle and 2000 rpm and note readings. Check timing at 2000 rpm and note reading.
Re: Yeah, It's Me Again [Re: Cab_Burge] #3134839
04/03/23 06:04 PM
04/03/23 06:04 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Cab. First off. Thanks. The ign timing is 2* ATDC. I'm changing wires this week. I like the distributor cap idea. What are they thru RockAuto, $10.? lol
Re: Yeah, It's Me Again [Re: Wicked49670dart] #3134842
04/03/23 06:11 PM
04/03/23 06:11 PM
Kudakidd Offline OP
Kudakidd  Offline OP
I'll take pics this week. . Replaced the mechanical fuel pump! Engine vacuum is a steady 21 in. of merc. lol. Have not checked timing at 2 rpm. Thank you for some great feedback!
Re: Yeah, It's Me Again [Re: Kudakidd] #3134843
04/03/23 06:16 PM
04/03/23 06:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Have you tries advancing the timing. I would be at least 5 to 10 BTDC.
Re: Yeah, It's Me Again [Re: NITROUSN] #3134941
04/04/23 12:03 AM
04/04/23 12:03 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
ATDC [censored] shruggy
I want my fair share
Re: Yeah, It's Me Again [Re: Kudakidd] #3134951
04/04/23 03:14 AM
04/04/23 03:14 AM
Your issue is the retarded ignition timing tsk
Set the initial to between 10 to 16 degree before top dead center and then rev the motor up with a good dial back timing light hooked up and working to find out where the max ignition timing is at, if it is less than 36 degrees BTDC go drive it, if it is more retard it until it is between 32 to 36 max BTDC wrench up scope
Beware, your going to wake up the Tiger so be careful on the first couple of WOT blast devil scope
Please let us know what you do and the results luck
Re: Yeah, It's Me Again [Re: Kudakidd] #3134952
04/04/23 03:16 AM
04/04/23 03:16 AM
Don't buy the cheapest ignition parts you can find tsk shruggy, you will get what you for and they may not last very long
Re: Yeah, It's Me Again [Re: Kudakidd] #3134988
04/04/23 09:28 AM
04/04/23 09:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2 AFTER ?? That I believe is the wrong direction, should be more like 5 before. Without knowing how much mechanical advance your distributor currently has ( factory is seriously 30 to 33 degrees) what you want to do is bring the RPM up to 3000 and set your timing at 34-36 before TDC and see how it responds ... make note of any pinging. Once you have it up at that RPM bring it up to 5000 and make sure it's not advancing more.
Re: Yeah, It's Me Again [Re: JohnRR] #3135386
04/04/23 07:22 PM
04/04/23 07:22 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2. With everything stock it probably won't be able to take much more than 36* above 3000 rpm, especially with a 4 speed. Total is more of a concern right now than initial with the backfiring through the exhaust and sluggish performance.
