Holley's new gas tank fuel level sensor #3133813
03/31/23 08:38 AM
03/31/23 08:38 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline OP
Pretty cool new part from Holley:: https://youtu.be/fqQiYJu0dms
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Holley's new gas tank fuel level sensor [Re: rumblefish72] #3133821
03/31/23 09:14 AM
03/31/23 09:14 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Heard about that.
Was wondering if it works with the factory gauge cluster.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Holley's new gas tank fuel level sensor [Re: rumblefish72] #3133866
03/31/23 11:32 AM
03/31/23 11:32 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
I am sure this is perfectly safe BUT I am still not sure I can wrap my head around having laser beams bouncing around inside my fuel tank. panic
Re: Holley's new gas tank fuel level sensor [Re: rumblefish72] #3133893
03/31/23 12:49 PM
03/31/23 12:49 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
How does it work on side mount style senders?
Re: Holley's new gas tank fuel level sensor [Re: A990] #3134049
03/31/23 09:33 PM
03/31/23 09:33 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It would be nice to see some instructions of some kind.
Re: Holley's new gas tank fuel level sensor [Re: GomangoCuda] #3134082
04/01/23 02:49 AM
04/01/23 02:49 AM
Laser beam are light waves, no electric current scope
Depending on the power source would determine how strong and which frequency they use for that laser light shruggy twocents
Re: Holley's new gas tank fuel level sensor [Re: 6PakBee] #3134084
04/01/23 03:40 AM
04/01/23 03:40 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I found the setup document. It's pretty limited use, foam baffled fuel cells are a no go, and I suspect vertical installs are too.
Attached PDF document
easy_level_sender.pdf (22 downloads)
Re: Holley's new gas tank fuel level sensor [Re: A990] #3134155
04/01/23 12:44 PM
04/01/23 12:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Did you mean "Horizontal?" the instructions posted show a vertical install
I would also wonder about tanks like most of the Mopars that are mounted at the top front, but angled downwards?
The issue I see on top mounted senders is floor clearance>
Next would be making an adapter for OEM style tanks. That likely add to the height issue
shruggy
Re: Holley's new gas tank fuel level sensor [Re: TJP] #3134160
04/01/23 01:09 PM
04/01/23 01:09 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
To clarify, this can't be mounted on tank sides or angled. I wonder if it can be immersed.
Its a shame the emitter cant be swiveled to accommodate more tank shapes.
Re: Holley's new gas tank fuel level sensor [Re: A990] #3134202
04/01/23 03:46 PM
04/01/23 03:46 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks!! up
