Re: Holley's new gas tank fuel level sensor
[Re: rumblefish72]
#3133821
03/31/23 09:14 AM
03/31/23 09:14 AM
Posts: 3,376 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Heard about that.
Was wondering if it works with the factory gauge cluster.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: rumblefish72]
#3133866
03/31/23 11:32 AM
03/31/23 11:32 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
I am sure this is perfectly safe BUT I am still not sure I can wrap my head around having laser beams bouncing around inside my fuel tank.
[Re: A990]
#3134049
03/31/23 09:33 PM
03/31/23 09:33 PM
Posts: 10,708 North Dakota
6PakBee
North Dakota
It would be nice to see some instructions of some kind.
[Re: A990]
#3134155
04/01/23 12:44 PM
04/01/23 12:44 PM
Posts: 15,323 Omaha Ne
TJP
Omaha Ne
I found the setup document. It's pretty limited use, foam baffled fuel cells are a no go, and I suspect vertical installs are too. Did you mean "Horizontal?" the instructions posted show a vertical install I would also wonder about tanks like most of the Mopars that are mounted at the top front, but angled downwards? The issue I see on top mounted senders is floor clearance> Next would be making an adapter for OEM style tanks. That likely add to the height issue
[Re: A990]
#3134202
04/01/23 03:46 PM
04/01/23 03:46 PM
6PakBee
North Dakota
I found the setup document. It's pretty limited use, foam baffled fuel cells are a no go, and I suspect vertical installs are too. Thanks!!
