Who runs a 295/65/15 on a 68-70 Charger? #3132397
03/26/23 10:01 AM
03/26/23 10:01 AM
North Texas
SOCAL Offline OP
SOCAL  Offline OP
North Texas
Thinking of running this tire out back. Anyone here run this size tire on a 68-70 Charger?
What rear suspension will help me hook on the street the best?
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: SOCAL] #3132399
03/26/23 10:06 AM
03/26/23 10:06 AM
North Texas
SOCAL Offline OP
SOCAL  Offline OP
North Texas
My gears are a 3.54
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: SOCAL] #3132423
03/26/23 11:33 AM
03/26/23 11:33 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Pu these on my Bro's Charger once to see how they fit. Fronts are 235/60. Normal street tires are 275/60 and car normally sits with a very slight rake. Drove it around the block without issue, but didn't do any further driving on it to see how they would have lived on the street. Don't know how they would have hooked up on the street either since street asphalt sucks. These were BFG G-Force drag radials on 15x8 Dragstar wheels. They would hook well enough at the strip to nearly lift the front tires on my drag car.
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: TC@HP2] #3132424
03/26/23 11:45 AM
03/26/23 11:45 AM
New York, USA
Chargerfan68 Offline
New York, USA
Back in 2008 I put these on my 68 Charger stickshift car along with “then” new SS springs. They were closer on the front side to qtr.. From memory, they had about 1” clearance. Went out for a test session on a pretty deserted road near me. Did a burnout and1st test launch after little spinning they hooked and bent the leafs. permanently bent front segments. The rear axle moved forward during this and the tires got into the front part of the rear quarters. Cut the tires some and and messed up the wheel trim a little.
I pulled those garbage springs off and went with Caltracs and 275-65-15s until they came out with 295/55-15 (which fit perfect and give me the width).
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: Chargerfan68] #3132450
03/26/23 02:24 PM
03/26/23 02:24 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I used to run them back in the 80's. Now down to a normal stock look no more rake.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: Chargerfan68] #3132526
03/26/23 08:37 PM
03/26/23 08:37 PM
North Texas
SOCAL Offline OP
SOCAL  Offline OP
North Texas
So you recommend Caltracs? Do your 295/55s hook well?
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: 6PKRTSE] #3132527
03/26/23 08:38 PM
03/26/23 08:38 PM
North Texas
SOCAL Offline OP
SOCAL  Offline OP
North Texas
Did you like them back in the 80s?
Re: Who runs a 295/65/15 on a 68-70 Charger? [Re: SOCAL] #3132581
03/27/23 12:35 AM
03/27/23 12:35 AM
New York, USA
New York, USA
I can only say the newer SSsprings did not work at all in my case. They actually bent and stayed bent. Maybe an older set (pre-2000) are better quality? The Caltracs on my car work very well. The drag radials I run are MT ET Street and work pretty good on the street after a little heat is in them. Car pulls good with them.
And the caltracs work very well at the track. Super consistent.
